cobcob Posted August 21, 2008 Share Posted August 21, 2008 Vehicle: 1982 DL Brat EA81, Hitachi carb 4 spd, Single range Symptoms: Stuck on high idle, RPM will not drop at the lights even after a 30 mile drive. Valves need adjusting. Going to do that this weekend (I know how to fix that but I'm wanting to throw it out there to give ALL the symptoms I've got going on right now) Engine "fluttering" or missing under load, it's got a HUGE deadspot when driving, not sure if that's related to the high idle situation or the loose valve train. There's just no more "go" no matter how far you bury the right foot, sometimes feathering the gas will cause it to pick up though. I thought it may have been bad gas but it's done it through 1.5 full tanks now. Checks done so far: 1. Nothing jamming the throttle cable etc. 2. Sprayed down all vac connections that I can find with electronics cleaner. No stumbles detected which would indicate a vac leak 3. I did re-gas my AC system the day before the troubles started. Should I be checking the "Idle up" solenoid on the AC system to see if it's jamming open? Plan of attack: Adjust valve train Check spark plugs and plug wires Change fuel filter Check idle up solenoid Any other suggestions would be appreciated Link to comment Share on other sites More sharing options...
mcbrat Posted August 21, 2008 Share Posted August 21, 2008 the dead spot/feathering through, sounds similar to a problem I had with my first brat. I put a can of seafoam in the gas tank, and added some to the carb throat trying to clean it out..... Link to comment Share on other sites More sharing options...
cobcob Posted August 21, 2008 Author Share Posted August 21, 2008 the dead spot/feathering through, sounds similar to a problem I had with my first brat. I put a can of seafoam in the gas tank, and added some to the carb throat trying to clean it out..... Thanks McBrat!! I assume that it worked? Link to comment Share on other sites More sharing options...
ettev Posted August 21, 2008 Share Posted August 21, 2008 Checks done so far:1. Nothing jamming the throttle cable etc. Still doesn't mean something within the carb isn't screwed up. Link to comment Share on other sites More sharing options...
mcbrat Posted August 21, 2008 Share Posted August 21, 2008 Thanks McBrat!! I assume that it worked? yes. for the sticking at high idle, others on the board have had the ASV system go bad, and have plastic sucked into the carb, making it do that.... make sure nothing is blocked in the throat of the carb.... Link to comment Share on other sites More sharing options...
mykingcrab Posted August 21, 2008 Share Posted August 21, 2008 My solution............ http://www.amazon.com/Weber-32-36-DGEV-SUBARU/dp/B000JLL04A/ref=sr_1_3?ie=UTF8&s=automotive&qid=1219349182&sr=8-3 Link to comment Share on other sites More sharing options...
cobcob Posted August 21, 2008 Author Share Posted August 21, 2008 My solution: Link to comment Share on other sites More sharing options...
mykingcrab Posted August 21, 2008 Share Posted August 21, 2008 you are definatly capable of both. that would be SWEET combined project "X" Link to comment Share on other sites More sharing options...
cobcob Posted August 22, 2008 Author Share Posted August 22, 2008 UPDATE This high idling is freaking absurd!! It's gotta be sitting around 1500 RPM or so and absolutely refuses to drop back. The one time I've noticed it drop back in the past 2 days has been when the AC turned off when I was dropping a movie at the store. The compresser kicked off and the idle dropped back to what it should be. It's stuck open again now though and bugging the hell out of me! Link to comment Share on other sites More sharing options...
McDave Posted August 22, 2008 Share Posted August 22, 2008 UPDATEThis high idling is freaking absurd!! It's gotta be sitting around 1500 RPM or so and absolutely refuses to drop back. The one time I've noticed it drop back in the past 2 days has been when the AC turned off when I was dropping a movie at the store. The compresser kicked off and the idle dropped back to what it should be. It's stuck open again now though and bugging the hell out of me! Apparently there is an electric (or maybe vacuum) solenoid on the side of the carb that opens the throttle with the a/c on. Unplug the solenoid and see if it idles lower. If it does, plug it back in and adjust it's adjustment screw to about 800 rpm. Link to comment Share on other sites More sharing options...
s'ko Posted August 22, 2008 Share Posted August 22, 2008 check your fuel pump. before mine went out, it surged like that a couple of times. BW Link to comment Share on other sites More sharing options...
cobcob Posted August 25, 2008 Author Share Posted August 25, 2008 So now I'm having trouble starting it when it's warm (stopped for gas 1/2 way to work today) I've got to floor it and crank then it'll catch on 1 or 2 cyls, kick and buck and then finally catch all 4. Not to mention it dieseled after I shut it off at the gas station... Link to comment Share on other sites More sharing options...
mcbrat Posted August 25, 2008 Share Posted August 25, 2008 So now I'm having trouble starting it when it's warm (stopped for gas 1/2 way to work today) I've got to floor it and crank then it'll catch on 1 or 2 cyls, kick and buck and then finally catch all 4.Not to mention it dieseled after I shut it off at the gas station... make sure your disty adjustment is tight. I had one "slip" and had to floor it to start.... Link to comment Share on other sites More sharing options...
cobcob Posted August 25, 2008 Author Share Posted August 25, 2008 Cheers Mick! I've got 1/2 a can of Seafoam in the fuel tank right now, I dumped the other half can through the carb on Saturday... Smelt great! I'm also going to stick some new plug leads on it tonight if I can get some at the parts store Link to comment Share on other sites More sharing options...
cobcob Posted August 25, 2008 Author Share Posted August 25, 2008 Well, this was left behind on the #3 plug when I pulled the plug lead to replace it... Hopefully THAT problem is solved... now still gotta nail down the high idle Link to comment Share on other sites More sharing options...
cobcob Posted August 26, 2008 Author Share Posted August 26, 2008 OK, the hesitation is gone now thanks to the plug wires. I've got a new bi-metallic choke on order to see if that kicks the idle back down like it should be. Link to comment Share on other sites More sharing options...
cobcob Posted August 26, 2008 Author Share Posted August 26, 2008 By a cruel twist of fate the hesitation/dead spot is back. Gas mileage is down the crapper too... I filled up on the way to work yesterday and I've burned 1/2 a tank doing 60 miles @ 55 - 60 mph. Usually I average upwards of 26 mpg, I think I'm currently getting closer to 9mpg Link to comment Share on other sites More sharing options...
Frank B Posted August 26, 2008 Share Posted August 26, 2008 The fast idle solenoid for the ac should be adjustable, but it is normal for it to be higher when the ac is on, but I don't know at what rpm. I would say 1000 tops. You may have to rebuild the carb, not hard really, just try to get an OEM kit. The ASV valve may be leaking too, the one that lets air from the intake into the exhaust for emissions. It has a reed valve in it and if it fails it will allow exhaust into the intake and screw things up a bit. Also check that the EGR isn't sticking open. Clean the PCV. Link to comment Share on other sites More sharing options...
cobcob Posted August 26, 2008 Author Share Posted August 26, 2008 Just wired the choke open. Even when the car is hot the choke was closed. I'll see if that resolves the issue. I've got another choke on order. Failing that I'll go back to checking PCV and ASV etc... 1 Link to comment Share on other sites More sharing options...
Frank B Posted August 27, 2008 Share Posted August 27, 2008 Just wired the choke open. Even when the car is hot the choke was closed. I'll see if that resolves the issue. I've got another choke on order.Failing that I'll go back to checking PCV and ASV etc... Well if your choke was closed, that would cover all the symptoms you described, except the high idle. Unless the choke linkage was holding the carb on fast idle. Link to comment Share on other sites More sharing options...
cobcob Posted August 27, 2008 Author Share Posted August 27, 2008 Seems to have fixed the problem, no more high idle, no more hesitation, and it idles so low at the lights that I have to rev it a little to make sure it's still running! Link to comment Share on other sites More sharing options...
