kimokalihi Posted August 24, 2008 Share Posted August 24, 2008 I may do an EJ22 Turbo swap into my NA 1990 subaru legacy AWD wagon. What all do I need to make this work? Probably the ECU. Do I need the whole wiring harness too? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 24, 2008 Share Posted August 24, 2008 ECU, Wireing harness, turbo engine cross-member, radiator and turbo water tank + all lines, complete exhaust system, boost control components from passsenger strut tower, fuel pump, etc. There is probably more but I know all that stuff is different. It's been done, but it best to have an entire turbo donor car (be it WRX, or whatever). It always easier to swap a different turbo engine into a chassis that was always turbo from day one than it is to swap from NA to turbo. You might consider just swapping to the phase III 2.5. It's the same stock power as the EJ22T - just doesn't have the overhead for modifications that the turbo's do. GD Link to comment Share on other sites More sharing options...
NoahDL88 Posted August 25, 2008 Share Posted August 25, 2008 I just so happen to have most everything to complete the turbo swap sitting in my back yard, the engine would need rebuilt but otherwise harness and whatnot is all there. Link to comment Share on other sites More sharing options...
kimokalihi Posted August 25, 2008 Author Share Posted August 25, 2008 I just found a cheap turbo touring wagon with a bad tranny and looks like it has body damage so I figured I'd swap the engine into my NA car that has a straight body and call it a day. But if I have to do all that...maybe not. There's another turbo sedan I have my eye on so I'm reconsidering. Link to comment Share on other sites More sharing options...
Legacy777 Posted August 25, 2008 Share Posted August 25, 2008 You don't need the complete harness. You just need to run the pins for the boost related sensors back to the ECU connector. Besides that, you need to swap the positive leads for the crank & cam sensors, and move the coolant temp sensor wiring down slightly on the engine harness. Much easier then swapping a complete harness. Also, the turbo legacy radiator won't fit in the non-turbo cars. It's taller. Link to comment Share on other sites More sharing options...
kimokalihi Posted August 25, 2008 Author Share Posted August 25, 2008 Thanks. So far I think I've abandoned the swap idea and I'm just gonna put my car up for sale and see if anyone wants it. Link to comment Share on other sites More sharing options...
wtdash Posted August 25, 2008 Share Posted August 25, 2008 Also, the turbo legacy radiator won't fit in the non-turbo cars. It's taller. Okay this is bad news! I just started this swap! Do I dare use the stock one, or get out the sledge and make room? Link to comment Share on other sites More sharing options...
Legacy777 Posted August 26, 2008 Share Posted August 26, 2008 Use the stock n/a one. I've been using it since I did my swap. If you have both radiators, I'd be interested in side-by-side pictures and dimensions. If you use the stock n/a radiator you need to tie the fitting near the radiator neck to the turbo coolant resevoir tank. You tie it to the port that was meant for the line that comes off the passenger side of the turbo radiator. You also need to remove the lower rubber gasket on the radiator cap so that coolant can flow to the turbo coolant resevoir tank. I know that sounds kind of complicated, but if you search the BBS it was discussed when a few times, including by myself. Josh Link to comment Share on other sites More sharing options...
