fajr22 Posted September 5, 2008 Author Share Posted September 5, 2008 Let me know what you guys need from my parts collection I would be more then willing to sell some stuff to fund the car.. FRED ASHMORE Quote Link to comment Share on other sites More sharing options...
zukiru Posted September 5, 2008 Share Posted September 5, 2008 how's the original 1.8? edit: I don't know why I asked that.. I know where 3 are right now. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 7, 2008 Share Posted September 7, 2008 i did know the 2.5 was not available in my car, but in short... i have already taken car of that issue.. the Sohc block has mor mains then the dohc, is that correct?? ALL EJxx motors have 5 main bearings. Phase 1 2.5l (the dual overhead cam ones) have the thrust bearing on a different main than the phase 2 (SOHC) 2.5l. All this means is that you have to keep the correct crank with the correct block. EJ22 heads on an EJ25 block make for good low end torque but no high end power. Good for a track with a lot of tight turns, not good for an open track. See this thread if you want to research that: http://forums.nasioc.com/forums/showthread.php?t=1107352 Intake manifold must match heads. The deck height on all the blocks is the same, but the port configuration is different. The wireing can be swapped from manifold to manifold easily, as to keep stock engine harness. Quote Link to comment Share on other sites More sharing options...
fajr22 Posted September 15, 2008 Author Share Posted September 15, 2008 Thanks for great info, i have been gone a while and when i came on earlier this week it said the board had been hacked.. So anyway, the 1.8 runs and drives it was parked because clutch was smoked, i have 2 of them and the turbo motor.. i am open to reasonable offers on all.. Lastly does the 2.2 turbo have better injectors?? thanx fajr22@yahoo.com Quote Link to comment Share on other sites More sharing options...
Zefy Posted September 16, 2008 Share Posted September 16, 2008 Thanks for great info, i have been gone a while and when i came on earlier this week it said the board had been hacked.. So anyway, the 1.8 runs and drives it was parked because clutch was smoked, i have 2 of them and the turbo motor.. i am open to reasonable offers on all.. Lastly does the 2.2 turbo have better injectors?? thanx fajr22@yahoo.com depends on your meaning of 'better'... yes i think they flow more fuel but the engine doesn't flow enough air to make it worth it (or make it faster). and unless you run some sort of EM there would be no way to control the extra flow from the injectors. Quote Link to comment Share on other sites More sharing options...
fajr22 Posted September 18, 2008 Author Share Posted September 18, 2008 thanx guys for the Help cage is ready and I will start other assembly this week!! fajr22@yahoo.com Quote Link to comment Share on other sites More sharing options...
monstaru Posted September 23, 2008 Share Posted September 23, 2008 deltacams will set you up with what you need.look in the vendor section....cheers, brian Quote Link to comment Share on other sites More sharing options...
