hawksoob Posted January 7, 2004 Share Posted January 7, 2004 My P-brake holds just fine. Problem is (if it IS a problem) it doesn't always do the clicky clicky. Meaning, I pull up and it locks into place, but no clicking. If I put it back down and go again, a bit more slowly, maybe "pump" it a little, it does the clicky clicky. Nice, firm grip. It holds just fine. No problem with the holdage. I've done the cable adjustment thing ... tightened it up a bit. Is this a symptom of a possible, potential problem? Stretched cable? Or is it a matter if, "Eh...it works....."? Link to comment Share on other sites More sharing options...
Setright Posted January 7, 2004 Share Posted January 7, 2004 Sounds suspicious. You should take off the housing and examine the ratchet mechanism. There must be something up. Link to comment Share on other sites More sharing options...
