Agteleni Posted August 31, 2008 Share Posted August 31, 2008 Hi everyone, The retractable cargo cover that fits in the back of my 1998 outback has a part that broke off - the plastic bracket on the right side that fits into the groove. Does anyone know how I can find this replacement part? I hate to buy a whole new cargo cover. I haven't been able to find one online - the closest thing I've seen is something on dealerfit.com called an "Outback tonneau cover plastic bracket," and is described as a "plastic part on the retractable cargo area cover that hold the cover in place". You can buy the right or left piece, but the problem is that there's no photo. Does anyone know 1) if this is the part I need and 2) if not, where I could find this part? Thank you! Eleni Link to comment Share on other sites More sharing options...
porcupine73 Posted August 31, 2008 Share Posted August 31, 2008 Are you sure it broke off? Some of them had a little screw that held it in and the screw would come out over time. Link to comment Share on other sites More sharing options...
Agteleni Posted August 31, 2008 Author Share Posted August 31, 2008 You're right - it's not broken, but the screw must have come out and the whole piece is missing (this happened a while ago, so the piece is long gone). any advice as to where to find a store/online vendor that sells these? thanks Eleni Link to comment Share on other sites More sharing options...
aircraft engineer Posted August 31, 2008 Share Posted August 31, 2008 That's the "fixed" side right? All that you need is a piece of plastic square about the right length and then find a screw that fits. It doesn't rotate and just hold the end "there". The end with the spring is the "window shade" I think. drill it to fit the screw and counterbore it if you need to if the piece is too long for the screw you just need something to hold it in place so it can't pull out Link to comment Share on other sites More sharing options...
porcupine73 Posted August 31, 2008 Share Posted August 31, 2008 You're right - it's not broken, but the screw must have come out and the whole piece is missing (this happened a while ago, so the piece is long gone). any advice as to where to find a store/online vendor that sells these? thanksEleni Oh sorry about that. Yes that happened to me too. I believe this page might have the part you seek: http://subarupartsforyou.com/cp_partlistbymod.php?model=Outback&subcat=Cargo+Curtain%2C+Hardware&year=1998 Link to comment Share on other sites More sharing options...
Agteleni Posted August 31, 2008 Author Share Posted August 31, 2008 Thanks for the tip! I don't have many power tools but someone else just posted the web site where I can buy the parts. Thanks again! That's the "fixed" side right? All that you need is a piece of plastic square about the right length and then find a screw that fits. It doesn't rotate and just hold the end "there". The end with the spring is the "window shade" I think. drill it to fit the screw and counterbore it if you need to if the piece is too long for the screw you just need something to hold it in place so it can't pull out Link to comment Share on other sites More sharing options...
Agteleni Posted August 31, 2008 Author Share Posted August 31, 2008 Thank you so much! Appreciate the tip! Eleni Oh sorry about that. Yes that happened to me too. I believe this page might have the part you seek: http://subarupartsforyou.com/cp_partlistbymod.php?model=Outback&subcat=Cargo+Curtain%2C+Hardware&year=1998 Link to comment Share on other sites More sharing options...
