Jellef Posted September 3, 2008 Share Posted September 3, 2008 Im changing a cv axle on the 83 brat turbo and i had a few questions. Where is the best place to purchase one? Will i be able to do this job with a Chiltons manual? Is there anything different about changing an axle on a turbo model than a gl? Link to comment Share on other sites More sharing options...
bratman18 Posted September 3, 2008 Share Posted September 3, 2008 Jellef said: Im changing a cv axle on the 83 brat turbo and i had a few questions. Where is the best place to purchase one? Will i be able to do this job with a Chiltons manual? Is there anything different about changing an axle on a turbo model than a gl? Should be a be to get one at any auto parts store but it will probably be a remanufactured one. You should be able to use the manual its pretty straight forward. And no it should be the same as changing one on a GL the splines are different but as long as you get a turbo cv axle than you won't have to worry about that!! Hope that helps Link to comment Share on other sites More sharing options...
ettev Posted September 3, 2008 Share Posted September 3, 2008 Just did one this weekend on a GL Brat. Got the shaft from NAPA. Fit correctly and no clicking. I think it was $65. As long as you're rooting around you may as well change the ball joint. That was $18 at NAPA. Both parts had to be ordered and they were in the next day. As posted by member General Disorder: Roll pin. Inner control arm bolt. Sway bar link. Pull axle off tranny. Drive axle out of knuckle. Reverse for installation. Check out these threads as well: http://www.ultimatesubaru.org/forum/showthread.php?t=90831 http://www.ultimatesubaru.org/forum/showthread.php?t=75786 Link to comment Share on other sites More sharing options...
bratman18 Posted September 3, 2008 Share Posted September 3, 2008 ettev said: Just did one this weekend on a GL Brat. Got the shaft from NAPA. Fit correctly and no clicking. I think it was $65. As long as you're rooting around you may as well change the ball joint. That was $18 at NAPA. Both parts had to be ordered and they were in the next day. Same here just did one last week and replaced the ball joint as well! Napa is where I would go as well always had good luck with there parts!! Link to comment Share on other sites More sharing options...
