JEGIII Posted September 4, 2008 Share Posted September 4, 2008 I'm looking to get a new set of lug nuts for my 97 OBW. I read in here somewhere that Sube's take a 30 degree seat, but all the aftermarket ones I can find are 60 degrees. Did I read wrong, or will I need a set of Subaru lugs? I'm looking for black ones to not show up so much against dark gray rims. Thanks for any info. Quote Link to comment Share on other sites More sharing options...
torxxx Posted September 4, 2008 Share Posted September 4, 2008 goto the junkyard pull em and put em in ur pocket, walk out Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 4, 2008 Share Posted September 4, 2008 I'm looking to get a new set of lug nuts for my 97 OBW. I read in here somewhere that Sube's take a 30 degree seat, but all the aftermarket ones I can find are 60 degrees. Did I read wrong, or will I need a set of Subaru lugs? I'm looking for black ones to not show up so much against dark gray rims. Thanks for any info. both correct 30 + 30 = 60 Quote Link to comment Share on other sites More sharing options...
JEGIII Posted September 4, 2008 Author Share Posted September 4, 2008 Not sure I follow. Here's what the folks at Gorilla show. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted September 4, 2008 Share Posted September 4, 2008 Or you could look at it this way: 60 + 30 = 90 It depends which baseline you use for measuring. Quote Link to comment Share on other sites More sharing options...
Mslatfly Posted September 4, 2008 Share Posted September 4, 2008 Or you could look at it this way: 60 + 30 = 90 It depends which baseline you use for measuring. You want to get more confused? Try working with a structural engineer, and tell him he's using the wrong baseline on a drawing he's designing for the part to be manufactured (baseline doesn't exist on the part, so angle cannot be measured directly once the part is cut to dimensions). Or better yet, two engineers working on the same part, and they use different baselines for the same angle. Quote Link to comment Share on other sites More sharing options...
Setright Posted September 6, 2008 Share Posted September 6, 2008 M12x1.25 with a 60 degree seat. Quote Link to comment Share on other sites More sharing options...
JEGIII Posted September 15, 2008 Author Share Posted September 15, 2008 :cool:Got the nuts from Summit Racing and a new set of Goodyear Assurance Triple-Treads. I think it came out good. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 15, 2008 Share Posted September 15, 2008 Quote Link to comment Share on other sites More sharing options...
