nwsunni Posted September 5, 2008 Share Posted September 5, 2008 Hi == Anybody want to take a stab at what this brand new problem might be? Auto: 89 Subaru Gl Sedan Manual 170,000 Miles and yes, it leaks oil. At idle, no unusual sounds. Seems fine. At idle, when I give it gas or back off the gas, I hear a rumble coming from the engine. It seems to be on the driver's side. When I hold the gas at a set speed, I don't hear the rumble. It's loud. It just started an hour ago. . Any suggestions on how I can better describe the noise? Thought it kinda sounded like exhaust but just had new muffler put on about a month ago. Link to comment Share on other sites More sharing options...
cobcob Posted September 5, 2008 Share Posted September 5, 2008 If you're suspecting exhaust then take a look at the Exhaust Manifold gaskets, and donut gasket... Doesn't sound like that from your description but it could be. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 5, 2008 Share Posted September 5, 2008 Sounds like a blown-out exhaust gasket to me. Having the muffler done wouldn't make any difference - in fact having it done so recently might have *caused* the blow-out due to jostling of the exhaust when they installed it and additional back-pressure from replaceing the old one that I assume had holes or other serious issues. They also may not have used the correct gaskets on the muffler-to-midpipe flange. If you don't use gaskets that have the metal sealing ring on the ID they will blow out quickly. GD Link to comment Share on other sites More sharing options...
nwsunni Posted September 5, 2008 Author Share Posted September 5, 2008 Thanks folks..for the speedy replies. Your replies prompted me to get under the car. Ick. Ouch. I can see a pipe up front that has a seam on it that has split. As you can tell, I'm no car expert. It looks like it's part of the exhaust system. If it's not one thing, it's... Link to comment Share on other sites More sharing options...
Indrid cold Posted September 5, 2008 Share Posted September 5, 2008 possibly ask local member to stop by and have a peek? The more you know the less chance getting taken $. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 6, 2008 Share Posted September 6, 2008 ... I can see a pipe up front that has a seam on it that has split... ...it is the Exhaust Pipe... Did you say "Rumble" Sound? ... Could it be a Worn Ball Bearing from one of the Timin` Belt`s Tensioneers? I Suggest to Start the Engine and go hear it close, accelerate it Manualy, Slowly untill the Noise Come and Go, and Try to Determine the place where it Comes From... Good Luck! Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 17, 2008 Share Posted September 17, 2008 Yeah, it sounds like exhaust to me. This spring I pulled an engine to fix... something - i don't remember, it becomes a blur after a while, - and three weeks after I put the engine back in, I started to hear a similar noise. I was sure I split the front pipe. When I finally got under and took a looksee, I found that some knucklehead (me) forgot to put the exhaust bolts on the passenger side exhaust manifold.... Link to comment Share on other sites More sharing options...
torxxx Posted September 17, 2008 Share Posted September 17, 2008 Hi == Anybody want to take a stab at what this brand new problem might be? Auto: 89 Subaru Gl Sedan Manual 170,000 Miles and yes, it leaks oil. If it doesnt leak oil, its not a subaru... Link to comment Share on other sites More sharing options...
