ea82T what should the compression be?
That's a bit low, but as long as they are even it should be fine. I don't have numbers for an EA82T but for the EJ22T the comp. is listed at about 140 psi. EA82T's are lower compression though so I would assume around 120 to 130 would be ideal.
You are doing the test with the throttle wide open right? Fuel pump disconnected?
  Quote
did the ea81t pistons lower the compression more?
From what I know both were 7.7:1 so they shouldn't have. The EJ22T is 8.0:1 for comparison. So it shouldn't be much lower in comp. numbers.
As I said though - it's a lot more important that they are even than it is for them to be high. Anything over 100 should run without any problems. Remember that the engine runs at a minimum of 700 RPM's. At speed the small leaks you are experiencing that bring your numbers down to 100 are going to be insignificant. It is a good indicator of general ring and valve sealing though so I wouldn't be boosting that engine to moon without a full overhaul - if the rings leak a bit you can collapse ring lands with too much boost.
  Quote
might i add the engine has 600 miles on a rebuild :grin:
Then either the rings haven't properly seated, or the hone job was crap. Were chrome rings used? It can take 10,000 miles for them to properly seat. 600 miles is nothing - I wouldn't be taking any readings till I ran that thing at 3k on the freeway for a couple hours.
And you better be changing the oil pretty soon. The first 1000 miles there's a ton of metal going to need to come out.
  • 2 months later...
