2.2 or 2.5 in 30th Anniv. Legacy Outback?
Hi all,
Sorry to bring this back up but after searching over the forum I'm still not
sure if the 30th Anniversary Legacy Outback sport sedan came with a 2.2
or 2.5 engine? My MIL is about to buy one from craigslist that states its a
2.5 DOHC. It is MINT condition and only has 108,000 miles. I'm a little
concerned because its an automatic, and i read that they have slipping
problems. Plus he wants $6,200! It is a pretty car though...
jimmy
They have the EJ25 - just like the owner is telling you.
Nice cars.
Test drive the car when it's cold...hasn't been started for a long time. Upon start up check for delayed shifting into drive.
Check the speedometer and drive it for quite awhile after it's warmed up to check for head gasket issues. Or ask the guy if the head gaskets have ever been replaced. A number of the legacy's i've bought have already been replaced prior.
Hi all,
jimmy
Check for the following also once warmed up, take to a parking lot and drive in circles tightly and see if you feel any vibration and torque binding to see if transfer clutches are ok. Check the underneath for common oil leaks such as camseals, crankseal, oil pump o ring, and valve covers on the sides, and the rear baffle plate leaking to, they had plastic ones in those years which leaked and they usually leaked in back of the oil pans and then onto exhaust.
Hi all,
jimmy
Those are very cool looking sedans for sure.
Be weary of the 2.5, see if the HG have been updated if not offer them 2000 off the price because they will blow, it is not a matter of if but when.
  • 2 weeks later...
Yes, I'm still a little wary of the car. It had a Reman Tranny put in by
the dealership around 50,000 miles ago (it currently has 108,000) and a
host of various oil leaks fixed, and a recent brake job but I see no
evidence of HG repair. When I asked the fellow on the phone he said it
had no problems with the HG. [Now that I think about it, the coolant was
a little low and I had to top it off! However, I looked under the car and it
had been sitting overnight, but I saw no sign of a leak?]
The main thing was I discovered it was a quart low of oil!! I called the guy
and he said maybe he "forgot" and only put three quarts in at the last oil
change (he did most of the work himself). He again assured me all was ok
with the car. Thankfully, the MIL hadn't driven a lot and I'm hopeful all is
well. Anyway, I told her she should have it checked by a shop and she
didn't want to take the time or spend the money ;-( Not my problem...
pc
