SUBARU3 Posted September 16, 2008 Share Posted September 16, 2008 I plan on storing a SOHC EJ 2.5 for some duration. Any suggestions on how to prep it for it's slumber? Also, if there is any remaining/ residual coolant in the water jacket, will that be OK for winter? (I don't believe a minimal amount of water freezing would damage anything). Thanks, Todd Quote Link to comment Share on other sites More sharing options...
mellow65 Posted September 16, 2008 Share Posted September 16, 2008 I plan on storing a SOHC EJ 2.5 for some duration. Any suggestions on how to prep it for it's slumber? Also, if there is any remaining/ residual coolant in the water jacket, will that be OK for winter? (I don't believe a minimal amount of water freezing would damage anything). Thanks, Todd in or out of a car? Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 16, 2008 Author Share Posted September 16, 2008 (edited) Its out of a car. Oil/coolant drained, spark plugs out/ rubber wire caps in. Todd Edited September 18, 2008 by SUBARU3 Quote Link to comment Share on other sites More sharing options...
mellow65 Posted September 16, 2008 Share Posted September 16, 2008 It out of a car. Oil/coolant drained, spark plugs out/ rubber wire caps in. Todd you should be fine the way it is. you might get some lite cylinder wall rust but probably not any thing to worry about. if it was me and i was planning on doing something to it ie, rebuild, head gasket, something. i would take the heads off and give a good coating of wd40 to the cylinders and a good coating to most everything. you just can't go wrong with a good coating of wd40. Quote Link to comment Share on other sites More sharing options...
davebugs Posted September 17, 2008 Share Posted September 17, 2008 I swear that I saw a 'fogging' product perhaps from sta-bil for storage like this. I've never used it though. Dave Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 17, 2008 Author Share Posted September 17, 2008 I guess my biggest concern was residual water freezing. Todd Quote Link to comment Share on other sites More sharing options...
mellow65 Posted September 17, 2008 Share Posted September 17, 2008 I guess my biggest concern was residual water freezing. Todd don't worry about that, it only an issue of cracking blocks when all the water passages are full with water and then it freezes and the ice has no where to expand and it cracks your block. if you have little pockets of water here and there in your motor there isn't anything to worry. you could rotate the motor on your stand a few times to get any little water that is left out, but i think that would be over kill Quote Link to comment Share on other sites More sharing options...
Buick350X Posted September 17, 2008 Share Posted September 17, 2008 a squirt of foggin oil or 2stroke oil in each cylinder once a month then turned over by hand to work it around. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 18, 2008 Author Share Posted September 18, 2008 Thanks guys.....I appreciate the feedback! Quote Link to comment Share on other sites More sharing options...
nipper Posted September 18, 2008 Share Posted September 18, 2008 http://seqair.com/skunkworks/Engine/Storing/Storing.html http://answers.yahoo.com/question/index?qid=20070731123424AAmW14H nipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 22, 2008 Share Posted September 22, 2008 Since it's out of the car, I'd be putting some LC20 in each spark plug hole and then turn the crank a few times to spread it around in the cylinder. Stuff an oily rag in the intake and exhaust ports. Not sure if there is any position like this but leave crank in a position with the most possible valves closed. Before the enigne was removed, it should have been run with gaosline with a stiff does of fuel stabilizer to help prevent gunking up of the injectors. Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted September 22, 2008 Author Share Posted September 22, 2008 Never thought of the "all valve closed". Makes sense, but how does one find that sweet spot? Todd Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 22, 2008 Share Posted September 22, 2008 hehe yes, the valves closed things I see in a lot of single cylinder small engines for generators, wackers, etc. It says to pull until you feel that it is on the compression stroke. Guessing there probably isn't a position though on the soob where all the valves on all the cylinders are closed. But stuffing the intake and exhaust ports with an oily rag could at least help keep moist air from comin in there. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted September 22, 2008 Share Posted September 22, 2008 i don't know where you are going to store this engine, but critters LOVE the leftover anti freeze. you might rinse it off. i wouldn't cover it or wrap it up, that just makes the critters think it's a great new place for acorn storage. i used foil backed hvac tape to close all of the openings and hose ends, which was very sticky and took some time to clean off but it sealed well. that tape is expensive, but i had it already. a heavy tin foil might work just as well. critters could still eat it but why would they. Quote Link to comment Share on other sites More sharing options...
