door window weatherstrip
torxxx
winters coming fast up here in alaska and I cant deal with the air leaks at my door glass anymore. Has anyone found a supplier for new rubber door seals/gaskets? EA82 wagon btw
I'm mainly looking for the window seals (ones that start at the A pillar and run up over the window to the b pillar) more than the door seals but both would be great.
I've adjusted the hell out of my door glass trying to get it to seal tighter and have used butyl tape around edges to attempt to get it to seal.
if anyones got some info plz let me know while I still have money :lol::lol:
Edited by torxxx
because I'm an idiot
Well, I cheated. I saved a set or 2 from cars I dissasembled for future anticipated use.
I've also thought about using RTV to rebuild a broken / bad spot, using saran wrap as a release layer and whatever else to hold the required shape while curing. I just have not had to do it yet....
I am parting an 85 wagon. The front window seals seem in good shape and I got them off in one piece. Those little push in clips are a pain. Barry
Edited by sparrowhawk
I am parting an 85 wagon. The front door window seals seem in good shape and I got them off in one piece. Those little push in clips are a pain. Barry
I agree the weather strip fits in a channel but mine also has a couple plastic clips that show as about 1/4" round plastic plugs at each end. These are there to stop it from pulling out of the channel at the ends. The door strip on mine is not in a channel and has even smaller T pins every few inches to hold it on the door. You can only see these by pulling the strip away from the door slightly being careful not to pull them out of the rubber seal. Barry
