bigo1966 Posted September 18, 2008 Share Posted September 18, 2008 I slid the antenna in and out out the car and now the radio no longer works. Whats up with that and how do i fix it????? Its this a common problem? Link to comment Share on other sites More sharing options...
torxxx Posted September 18, 2008 Share Posted September 18, 2008 should still work. I cut my antenna off at the mount because it kept getting bent when I was wheeling and it wouldnt push down in the a pillar anymore. I still get radio from about 20 miles away with a 1/4 stub sticking out. maybe you wire popped out of the back of the stereo and its coincidence that it happened at the same time you pushed the antenna down Link to comment Share on other sites More sharing options...
bigo1966 Posted September 18, 2008 Author Share Posted September 18, 2008 good point, ill check that out. will the radio still work if the antenna cable just popped out of the antenna? Link to comment Share on other sites More sharing options...
torxxx Posted September 18, 2008 Share Posted September 18, 2008 yeah theres a cable underneath the dash kind of by the relays that connects the antenna wire to the extention wire that reaches the deck Link to comment Share on other sites More sharing options...
bigo1966 Posted September 18, 2008 Author Share Posted September 18, 2008 That could be in then. I was messing with all that stuff the other day installing the ignition. Link to comment Share on other sites More sharing options...
