mcbrat Posted September 18, 2008 Share Posted September 18, 2008 Planning Started made initial purchase yesterday 4 axle brackets, 2 rights and 2 lefts, all with a 10 degree offset 4 adjustable link mount brackets 4 tube link brackets, 2 rights and 2 lefts, all with 10* offset 3 upper control arm brackets flat mount 1 upper control arm axle bracket 8" 8 bushing kits 4 Large RE joints 4 Forged Johnny Joints 1" shank RH thread w/jams & tube adapters more to follow.... Link to comment Share on other sites More sharing options...
bheinen74 Posted September 18, 2008 Share Posted September 18, 2008 mick, your list or parts scares me.......monster brat perhaps? Link to comment Share on other sites More sharing options...
TeamCF Posted September 18, 2008 Share Posted September 18, 2008 Judging from that list of parts. I like where this is going. Link to comment Share on other sites More sharing options...
mcbrat Posted September 24, 2008 Author Share Posted September 24, 2008 57 pound box arrived yesterday.... I'll try to get some pics.... Link to comment Share on other sites More sharing options...
monstaru Posted September 25, 2008 Share Posted September 25, 2008 i actually did some measuring for this.i figured if i made a subframe to all of the regular suspension mounting points and made the center section a combo transfer case/link mounting area it would work out better. as opposed to try and weld the center mounting area directly to the body. anyways.awesome,am looking forward to seeing how it comes out. eventually i will actually follow through with this one. i only started it 2 times already.got closer the second time.cheers, brian Link to comment Share on other sites More sharing options...
MorganM Posted September 26, 2008 Share Posted September 26, 2008 How goes the upgrade project? 1 Link to comment Share on other sites More sharing options...
mcbrat Posted September 26, 2008 Author Share Posted September 26, 2008 got the RE joints the day before yesterday. I'm still waiting to get the '87 4Runner rear axle, steering box, and front hubs before it goes into full deconstruct mode. I'll be removing some stuff from my Brat but still keep it driveable so I can drive it out to the shop. Link to comment Share on other sites More sharing options...
mcbrat Posted November 14, 2008 Author Share Posted November 14, 2008 got the '87 4 runner rear axle, and steering box.... I'll try to get the pics to start showing the build as we go..... Link to comment Share on other sites More sharing options...
mcbrat Posted November 16, 2008 Author Share Posted November 16, 2008 I know, I know.... pics.... maybe later tonight... The engine and tranny crossmembers are back in stock locations. definitely need to remove the couple of carb spacers from the weber... complete rear subframe is removed and all front suspension/steering stuff removed. still need to remove the gas tank ande-brake handle.... Link to comment Share on other sites More sharing options...
mcbrat Posted November 17, 2008 Author Share Posted November 17, 2008 Okay, so a bit of history on this Brat... I got it in Feb. '03, came from AZ, engine was trashed, no fluids anywhere... a complete build was in order.... Put a 4/3 lift in, rear disk brakes, complete brake system flush, etc.... finally got an engine and in Aug, it moved under it's own power for the first time in probably 14 years... Since then, it's gotten lots of decals, lots of dents, suspension changes, lift changes, etc.... all making it better each time, but always leading to the next weakest link.... Here it was in July of 2008... Link to comment Share on other sites More sharing options...
mcbrat Posted November 17, 2008 Author Share Posted November 17, 2008 Parts mentioned in the first post.... also purchased a Samurai transfer case... and a few years back, I had purchased a '85 toyota from a junkyard. parted it out, and here's what's left after finally removing the axles. I also got a wider rear axle out of a '87 4-runner so it at least matches the width of the soob rear.... and then cut up and ready for the recycler... Link to comment Share on other sites More sharing options...
mcbrat Posted November 17, 2008 Author Share Posted November 17, 2008 The deconstruction begins.... Definitely need to take the carb and intake spacers off... or cut a big hole in the front of the hood actually, SPFI will be coming next summer probably.... Link to comment Share on other sites More sharing options...
mcbrat Posted November 17, 2008 Author Share Posted November 17, 2008 what do you think...? Just a little more bashing? actually, those are a little bigger than what'll be on it.... moving rear axle back a bit, and the front axle forward more... probably looking at 105" wheelbase... and will definitely be losing sheetmetal.... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted November 17, 2008 Share Posted November 17, 2008 Mick what are your plans for the front axle? Link to comment Share on other sites More sharing options...
mcbrat Posted November 17, 2008 Author Share Posted November 17, 2008 Mick what are your plans for the front axle? I'll be running the '85 toy front axle, with the '87 4-runner IFS steering box. Chris (the design/fab guru) will be deciding whether to go 3 link or 4 link in the front. Link to comment Share on other sites More sharing options...
bheinen74 Posted November 17, 2008 Share Posted November 17, 2008 can't wait for thread updates:popcorn: Link to comment Share on other sites More sharing options...
The Dude Abides Posted November 17, 2008 Share Posted November 17, 2008 brakes:D Link to comment Share on other sites More sharing options...
Numbchux Posted November 17, 2008 Share Posted November 17, 2008 excellent let me know if you need any yota drivetrain parts. I'm parting out an '86 IFS 4Runner right now. I'm keeping the engine, tie rods and front axles for sure. pretty much anything else is up for grabs. Link to comment Share on other sites More sharing options...
mcbrat Posted November 18, 2008 Author Share Posted November 18, 2008 Took a few more pics tonight with my good camera, when I went over to drain the gas tank, and pick up the no longer needed soob parts... Chris already had the front axle positioned under it to get a feel for placement, etc... The exhaust definitely needs changed up front.... Link to comment Share on other sites More sharing options...
bheinen74 Posted November 18, 2008 Share Posted November 18, 2008 whats the plan on passenger side exhaust? looking like got some good progress momentum now. Link to comment Share on other sites More sharing options...
mcbrat Posted November 18, 2008 Author Share Posted November 18, 2008 whats the plan on passenger side exhaust? looking like got some good progress momentum now. probably need to come forward and loop to the drivers side. like a flipped turbo cross-over.... Link to comment Share on other sites More sharing options...
The Dude Abides Posted November 18, 2008 Share Posted November 18, 2008 Thats Mantastic mick. Link to comment Share on other sites More sharing options...
Numbchux Posted November 18, 2008 Share Posted November 18, 2008 Link to comment Share on other sites More sharing options...
TheYeti Posted November 19, 2008 Share Posted November 19, 2008 Very cool, Mick! Link to comment Share on other sites More sharing options...
The Beast I Drive Posted November 19, 2008 Share Posted November 19, 2008 I think a Turbo exhaust header from a EA82 with some mods to the crossmember would clear your pumpkin, what say ye? Looks like its gonna be fun, Im workin on a straight axle rig myself -Bill 1 Link to comment Share on other sites More sharing options...
