XTREME RACING Posted September 20, 2008 Share Posted September 20, 2008 I have been reading the forum for the last couple of months since I got my 86 Brat and having been learning from the site. It is great!!!! I guess my question is what can I do for more power out my EA81? Like I said I have an 86 Brat it and it only has alittle of 40K miles and NO rust so I am wanting to give it a little more power using the stock power plant at this time. It is going to be a shop truck for my company so I dont want to go crazy with it yet until I figure out what is possible and who might all drive it. Thanks for any info. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 20, 2008 Share Posted September 20, 2008 you can swap on an ea82 hitachi or even the whole intake. typical route is to do a weber swap. you could even swap in an ea82 with monor mod. otherwise if you open up the exhaust a little(custom fab from cat back, your typical off the shelf exhaust pipes bent to fit, and a cherry bomb!) and bump up the timing a few degrees will make it a little more peppy. Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted September 22, 2008 Share Posted September 22, 2008 That and a cam are about the best you're gonna get. Check out http://www.ultimatesubaru.org/forum/showthread.php?t=67317&highlight=engine+rebuild for more info. Quote Link to comment Share on other sites More sharing options...
XTREME RACING Posted September 22, 2008 Author Share Posted September 22, 2008 Thanks this is a starting point on the car. I was thinking of the Weber carbs but I like the idea of fuel injection better so I might see what I can find. Here are some ideas I have come up with at this time, Weber carbs or FI port and polish the heads new exhaust system mill the heads for more compression new (modified) cam Quote Link to comment Share on other sites More sharing options...
crockettbrat Posted September 22, 2008 Share Posted September 22, 2008 I recommend the ej swap! It's really not all that difficult, and the power increase is great. It may seem daunting, but its not that bad. The cost depends on how lucky you get on your donor vehicle. Go for it! Daniel Quote Link to comment Share on other sites More sharing options...
XTREME RACING Posted September 22, 2008 Author Share Posted September 22, 2008 I thought about an EJ motor swap but not wanting an EJ motor at this time. If I did anything I would do an EA82T motor swap, I just have to be different:grin: Quote Link to comment Share on other sites More sharing options...
Phizinza Posted September 23, 2008 Share Posted September 23, 2008 I thought about an EJ motor swap but not wanting an EJ motor at this time. If I did anything I would do an EA82T motor swap, I just have to be different:grin: 5 years ago that was all the rage. But now people have seen that its pretty much the same amount of work to put an EJ22 in which has more power without a turbo. And its more reliable. Just stick with the simple stuff. Open up the exhaust flow, stick a weber on it, play with the timing and do the other service stuff. New good oil can actually make a difference on a dyno you know, so all the little stuff adds up. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted September 23, 2008 Share Posted September 23, 2008 And if you get extremely lucky like a certain board member coughPsycocough you might be able to find yourself a JDM EA81. Ive been looking a bit myself but so far have come up dry. As far as i can tell in my research the JDM EA81 had reversed valves from normal EA81s, as in the intake valve is where the exhaust valve is and visa versa. This necessitates a different cam. The exhaust ports are different and it had a dual carb intake. All this added up to 103-108hp depending on what u read. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted September 24, 2008 Share Posted September 24, 2008 And if you get extremely lucky like a certain board member coughPsycocough you might be able to find yourself a JDM EA81. Ive been looking a bit myself but so far have come up dry. As far as i can tell in my research the JDM EA81 had reversed valves from normal EA81s, as in the intake valve is where the exhaust valve is and visa versa. This necessitates a different cam. The exhaust ports are different and it had a dual carb intake. All this added up to 103-108hp depending on what u read. It's not all JDM EA81's like this. Only a select few performance models. I have one too.. I read 101hp on a Ultralite website (their the dudes who picked most of them up years ago and thus hard to fine now.) Quote Link to comment Share on other sites More sharing options...
XTREME RACING Posted September 24, 2008 Author Share Posted September 24, 2008 Dang, I thought maybe finding the heads would be easy but I guess not. Living in SC makes it hard finding parts also, not many subaru's in this area. Quote Link to comment Share on other sites More sharing options...
Awddrift4 Posted September 25, 2008 Share Posted September 25, 2008 Dang, I thought maybe finding the heads would be easy but I guess not. Living in SC makes it hard finding parts also, not many subaru's in this area. try living in kansas... subarus are rare here Quote Link to comment Share on other sites More sharing options...
bratman18 Posted September 26, 2008 Share Posted September 26, 2008 try living in kansas... subarus are rare here Try living in Maine there are tons of subarus but no older ones!! And if there are any they are rusted right to the door handles!! Quote Link to comment Share on other sites More sharing options...
cobcob Posted September 26, 2008 Share Posted September 26, 2008 Try living in Missouri! Just cos it's better than Kansas and more temperate than Maine Quote Link to comment Share on other sites More sharing options...
XTREME RACING Posted September 26, 2008 Author Share Posted September 26, 2008 I guess it could be worse, could be Florida. I dont think they know what a Subaru is. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted September 26, 2008 Share Posted September 26, 2008 Try living in Washington! We don't have any Suba... oh wait, nevermind! Quote Link to comment Share on other sites More sharing options...
Psyko Posted September 27, 2008 Share Posted September 27, 2008 Try living in Washington! We don't have any Suba... oh wait, nevermind! No, really, Washington is a difficult place. It's sad how many Subarus you have to pass on simply because of money and space. You can't have them all. :-p Btw, Hatchsub, you spelled my name wrong. Psyko. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted September 28, 2008 Share Posted September 28, 2008 I don't think where you live is going to have an effect on finding the dual carb parts or whole dual carb motor. You'll have to probably find one from overseas anyhow. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 28, 2008 Share Posted September 28, 2008 According to the Subaru literature the factory dual carb engines were 108 HP. These still were not the dual-port heads though - just better flowing. And it takes more than the heads because as mentioned the valves are reversed so you need the cam or a custom one to match. Subaru also made a variation which I have not seen outside of race/rally prepped vehicles that surely must have put down more than the 108 of the production model. It had carbs mounted to each head rather than to a manifold. I would guess that if it were anything like the RAM engines it was probably putting down closer to 130 to 140 HP. Perhaps even more considering that the Subaru engineers got 120 HP out of the 1.0 liter justy engine for bonneville. GD Quote Link to comment Share on other sites More sharing options...
bratman18 Posted September 28, 2008 Share Posted September 28, 2008 Try living in Washington! We don't have any Suba... oh wait, nevermind! oh you so funny! Send a few my way! Quote Link to comment Share on other sites More sharing options...
brewtownbrat Posted October 1, 2008 Share Posted October 1, 2008 does anyone know where i could find more info on this 1.0L justy motor for bonneville? i'm sure a wicked port/deck job, weber, ported/fabbed intake manifold, hot cam and a good exhaust could get a stock 81 in the 100-110 hp range... it doesn't take much. Quote Link to comment Share on other sites More sharing options...
