mcbrat Posted September 21, 2008 Share Posted September 21, 2008 a buddy of mine in town (not a board member) is trying to replace the input shaft seal on a j/y 5 speed before he puts it into his lifted 87 wagon. can this seal be replaced without cracking the tranny case? he's having difficulty removing the plate covering it? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 21, 2008 Share Posted September 21, 2008 There was a discussion about this a while ago - I believe the solution after much cursing was to loosen the bolts that hold the case halves together. GD Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 21, 2008 Share Posted September 21, 2008 Ok - I found the thread: http://www.ultimatesubaru.org/forum/showpost.php?p=739865&postcount=37 Specifically, after having a heck of a time with it, he disassembled the tranny and found: By the way the front input shaft seal does not come out without splitting the case apart and removing the entire input shaft and bearing assembly because the bearing is retained by a snap ring to the front cover. So I guess that settles it. GD Link to comment Share on other sites More sharing options...
mcbrat Posted September 21, 2008 Author Share Posted September 21, 2008 thanks. Link to comment Share on other sites More sharing options...
