dave valiant Posted September 23, 2008 Share Posted September 23, 2008 A friend of mine has Legacy turbo wagon that the keyway on the crank for the harmonic balancer is all screwed up and the balancer wont stay on. His plan is to weld it on, which I told him was a bad idea, and if that doesnt work is going to sell it for scrap. Is the engine worth anything like this and does anyone know if na and turbos engines use the same crank shaft? Link to comment Share on other sites More sharing options...
torxxx Posted September 23, 2008 Share Posted September 23, 2008 If u know someone that can tig weld, that keyway is fixable. I myself have welded a few EJ22 N/A motors back together like such. its kinda hard to do, but considering its a ODB 1 engine, the ecu controls the timing so a 1/8" isnt really going to make too much of a difference. I've also JB welded the keyways back into place when I didnt have access to a tig welder. it all comes down to how far it stripped the crank. A picture is worth a grand if u can get one for us Link to comment Share on other sites More sharing options...
idosubaru Posted September 23, 2008 Share Posted September 23, 2008 dave - not worth scrapping it for. there's a kit made by a company to fix this actually. it's expensive but worth it to avoid scrapping a good car or welding. if by welding you mean welding the pulley to the crank that's a very bad idea in my opinion. if you mean fixing the crank to properly attach the pulley then go for it if you have the resources to do it. for what it's worth on the EJ22's it's possible to change the timing belts without removing the crank pulley, so if he does decide to weld it, just tell him to leave the covers off...or at least the center cover, then the timing belt is changeable. if doing this, i'd go ahead and replace the pulley to the upper right with a new one since that won't be replaceable with a "fixed" crank pulley. Link to comment Share on other sites More sharing options...
dave valiant Posted September 23, 2008 Author Share Posted September 23, 2008 Any info on the company that makes the fix kit? Link to comment Share on other sites More sharing options...
idosubaru Posted September 23, 2008 Share Posted September 23, 2008 sorry dave i can't recall. i've seen it but never used it yet. search for it here and google. EJ crank fix or EJ22 crank or EJ25 crank kit....some variation of those terms. i would look it up but i'm on dial up at the moment so my hands are tied. Link to comment Share on other sites More sharing options...
dave valiant Posted September 23, 2008 Author Share Posted September 23, 2008 Thanks Gary I will give that a look. Link to comment Share on other sites More sharing options...
subaru360 Posted September 23, 2008 Share Posted September 23, 2008 The crank is the same as all the other 2.2's so you can just pick up a used crank and install it rather than try to weld it. The EJ22 turbo block is the strongest block subaru ever made. It's worth more than scrap if you decide to sell it. If you decide to scrap it I will buy it for a fair price, I want one for my wrx. Link to comment Share on other sites More sharing options...
torxxx Posted September 23, 2008 Share Posted September 23, 2008 gary I'm talking bout welding the keyway back into the crank.... I'd never weld a pulley to a crankshaft... lol Link to comment Share on other sites More sharing options...
idosubaru Posted September 23, 2008 Share Posted September 23, 2008 gary I'm talking bout welding the keyway back into the crank.... I'd never weld a pulley to a crankshaft...lol ha ha! lol indeed. i knew you meant the keyway, that's a stellar idea. i think in the original post though it sounded like his friend meant the pulley to the crank. Link to comment Share on other sites More sharing options...
dave valiant Posted September 24, 2008 Author Share Posted September 24, 2008 That is exactly what he is intending to do. If he screws it up and I get I plan on selling the turbo block and throwing in an na engine. The car is super clean. Link to comment Share on other sites More sharing options...
