fshnidiot Posted September 24, 2008 Share Posted September 24, 2008 Air suspension. I just pushed the height control button. It only gives you an inch or 2 but with that and the pugs it looks more like a real 4WD to me. Frank Link to comment Share on other sites More sharing options...
Turbone Posted September 24, 2008 Share Posted September 24, 2008 Frank, I think your XT is originally from Canada. They were the only ones in NA to get the height adjustable air suspension. I believe there is a way to make a switch to make it manually adjustable. If you go do a search at www.subaruxt.com you might come up with something. Link to comment Share on other sites More sharing options...
fshnidiot Posted September 25, 2008 Share Posted September 25, 2008 Frank, I think your XT is originally from Canada. They were the only ones in NA to get the height adjustable air suspension.I believe there is a way to make a switch to make it manually adjustable. If you go do a search at www.subaruxt.com you might come up with something. I got it up in Bellingham so it might have come from Canada originally. I'll check the XT site for the manual switch idea, that could be cool! Thanks!!! Frank Link to comment Share on other sites More sharing options...
89subiext Posted September 26, 2008 Author Share Posted September 26, 2008 No one answered my question. How much will those 2wd xt rear struts lift my car? and how much do the front ajustable struts lift it? Link to comment Share on other sites More sharing options...
one eye Posted September 26, 2008 Share Posted September 26, 2008 This is mine. I just put rear struts off of an 88 GL wagon on the rear and linked the two front air shocks together, then I put 90psi in them this is what I got The Tires I have on it are 195/65/390mm but I think I could shove a 27x8.50x14 wildcat under it. The best way to lift it would be to check out the SJR 2" that could give you a good Idea as to what you might need to do to make it a bit more bullet proof. Jeff Jeff Link to comment Share on other sites More sharing options...
