Scott in Bellingham Posted September 24, 2008 Share Posted September 24, 2008 can this engine run without a computer , say with a carb and a ???? disty?? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 24, 2008 Share Posted September 24, 2008 If it was carbed, yes. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 24, 2008 Author Share Posted September 24, 2008 If it was carbed, yes. I have EA82 SPFI , so if I get a carbed intake and a a carbed disty theres no computer?? Link to comment Share on other sites More sharing options...
The Dude Abides Posted September 24, 2008 Share Posted September 24, 2008 y fi is better. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 24, 2008 Author Share Posted September 24, 2008 y fi is better. why? I have a turbo mpfi car with the wrong comp and wiring and I have a good EA82 SPFI engine Link to comment Share on other sites More sharing options...
Numbchux Posted September 24, 2008 Share Posted September 24, 2008 yea, the carbed ones will, but not terribly well. if you go that route, don't get a stock carb. I had an '85 with a feedback carb, blew the fuse for the ECU (and didn't figure it out for a couple days....). it still ran, but extremely rich, had no power at all. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 24, 2008 Share Posted September 24, 2008 get a Hitachi distributor from a carbed EA82 and put a Weber on a carbed manifold and your all set. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 24, 2008 Author Share Posted September 24, 2008 get a Hitachi distributor from a carbed EA82 and put a Weber on a carbed manifold and your all set. so the carbed EA82 has a stand alone disty that takes no comp? Link to comment Share on other sites More sharing options...
Rollie715 Posted September 24, 2008 Share Posted September 24, 2008 Scott, The EA82 I got from Japan had a Carb and Disty on it. They may be still lying around the shop somewhere. Rollie Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 24, 2008 Share Posted September 24, 2008 so the carbed EA82 has a stand alone disty that takes no comp? Yep. Its about as simple as it gets. Link to comment Share on other sites More sharing options...
Snowman Posted September 24, 2008 Share Posted September 24, 2008 Yeah, you can go from SPFI to carbed or vice versa no problem. I would recommend getting the stuff from a junkyard or parts car to convert to SPFI. It's a long day's worth of electrical work, but not that hard. General Disorder and myself have compiled manuals on converting from carb to SPFI that explain everything you need to do to make it run. SPFI > carb Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 25, 2008 Author Share Posted September 25, 2008 Scott, The EA82 I got from Japan had a Carb and Disty on it. They may be still lying around the shop somewhere. Rollie your right I found one tonight , I think Ill put the EA82 with carb into the turbo car and sell the turbo, other then trying to get it to run right , then rework the rear section for massive flex:) Link to comment Share on other sites More sharing options...
