coupe Posted September 25, 2008 Share Posted September 25, 2008 Hi Gang I have a blown turbo 88 Ea82. If i use a non turbo MPFI Ea82 and have the head tapped for the turbo oil line and change the water pump etc, will the increased compression of the MPFI be a hinderance for the car. ( 9 .5 compaired to 8.5) Its not a car im going to be using for hooning. Its a XT 4wd . Is there anything i should know i havent allowed for. Thanks Pete Link to comment Share on other sites More sharing options...
mykingcrab Posted September 30, 2008 Share Posted September 30, 2008 (edited) Not sure,but aleast you deserve a bump to the top. There are some old threads, if you keep searching for high compression ea82t,or similar phrases, you should find some info. and really keep digging, there are some people that have done this and raced them. ive seen several vw, blow thru set ups running 5-7 9:1 psi ,with no problems. Edited September 30, 2008 by mykingcrab Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 30, 2008 Share Posted September 30, 2008 It's not a recommended combination without supporting mods like an intercooler. The EA82T's are not 8.5:1, they are 7.7:1, and not real reliable even at that. The carb blocks are 8.5:1. Dump the whole mess and install an EJ22. More power and 10x more reliable. GD Link to comment Share on other sites More sharing options...
Snowman Posted September 30, 2008 Share Posted September 30, 2008 I would agree with GD that once you're in it that far, an EJ22 conversion is probably not much more expensive and will result in way more car. However, if you're into running a high-compression turbo engine, it has been done by several board members with varying degrees of success. I've read most of the discussions on the topic, and it seems that if you ran an intercooler and kept the boost levels stock (maybe even turn it down a hair with a controller), it would run reliably for a while. Another good bit of insurance would be to install a new 2 row radiator if it doesn't already have one. You will run into trouble if you crank up the boost and/or otherwise hot rod it, as many people have found out. Link to comment Share on other sites More sharing options...
coupe Posted October 2, 2008 Author Share Posted October 2, 2008 Thanks Gang I m not up to putting a ej22 in yet $ pending. Im not wanting to up boost or hotrodding the car. At the momment i just want to find reasonable fix for cooked motor. So i was going to use a MPFI and add on the outer bits, retapp oil feed etc. Cheers Pete Link to comment Share on other sites More sharing options...
