onsight Posted September 25, 2008 Share Posted September 25, 2008 Hi everyone, I've being doing my research here for a while, first time post. I am eyeing on a 92 loyale with 5spd. I am going to see it tonight, the owner asks for 700 or obo. just called him, seems the car leaks oil a bit (not sure where, have to go take a look myself), and radiator has just been replaced. other than that, seems like a OK car. so, the question is: What should I look for when I get to see the car, especially relate to leak and overheating problems. EA82 is new to me, links pointing to pictures will be really useful, too. Thanks. hope I can get the loyale I want and join the family. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted September 25, 2008 Share Posted September 25, 2008 depending where you are in the country, rust might be an issue. and not just cosmetic rust, get down on the ground and make sure it's structurally sound. the oil leak isn't really anything to worry about, pretty hard to keep an EA82 from leaking. usually the valve covers are the first place to leak, but unless meticulously maintained, they'll seep a bit from everywhere. that's about all I can think of for now... Quote Link to comment Share on other sites More sharing options...
robm Posted September 25, 2008 Share Posted September 25, 2008 Places to look for oil leaks: Cam covers Front seal ( hidden behind timing belt covers) Cam seals (ditto) Oil oump seal (ditto) Oil pan gasket Most of these are pretty easy to fix. New rad could be because of overheating problems, which took out head gaskets. Look for oily stuff in the coolant, steam in the exhaust (when thoroughly warmed up), coolant smell in the exhaust. Quote Link to comment Share on other sites More sharing options...
onsight Posted September 25, 2008 Author Share Posted September 25, 2008 Thanks for quick reply, Numbchux, I remember reading your EA82 to EJ22 swap post, very impressive. I asked about rust over phone, seems it's not issue(california car), but I'll definitely get down to check the structure. Quote Link to comment Share on other sites More sharing options...
onsight Posted September 25, 2008 Author Share Posted September 25, 2008 Places to look for oil leaks: Cam covers Front seal ( hidden behind timing belt covers) Cam seals (ditto) Oil oump seal (ditto) Oil pan gasket Most of these are pretty easy to fix. New rad could be because of overheating problems, which took out head gaskets. Look for oily stuff in the coolant, steam in the exhaust (when thoroughly warmed up), coolant smell in the exhaust. that's what I figure, too. Will test drive help detecting overheating problem? if so, usually how long do I need to drive it (like on freeway) to bring up any effect. And is there any gauge I should keep my eye on while test driving? Quote Link to comment Share on other sites More sharing options...
onsight Posted September 25, 2008 Author Share Posted September 25, 2008 B.T.W. suppose there's HG problem, normally how much it will cost to fix it? and is the engine is really beaten, Is it hard to find another good (JDM?) EA82 for swapping? Quote Link to comment Share on other sites More sharing options...
robm Posted September 25, 2008 Share Posted September 25, 2008 These warm up fast. If the HG is bad, it can show up at the wierdest times, in stop and go traffic, stopped at a light, or at WOT up a hill. Look for the temperature gauge fluctuating. If it is nice and stable, and about 1/4 - 1/3, it is working right. It might rise slowly if you run at WOT up hill for awhile, or try to see how fast the car will go, but the gauge shouldn't move fast once it is warmed up. Look for the level in the rad, too. Quote Link to comment Share on other sites More sharing options...
onsight Posted September 26, 2008 Author Share Posted September 26, 2008 Thanks for all the replies, There's no deal. I'll keep looking. Quote Link to comment Share on other sites More sharing options...
