brus brother Posted September 26, 2008 Share Posted September 26, 2008 My 2008 has an intermittent rattle when going over bumps. It was tough to isolate but I finally figured out that it was coming from the ABS manifold/actuator in front of the passenger strut tower. If I tap on the black actuator in front of the manifold there is an audible rattle. I checked another 08 in the showroom and it doesn't make the sound. The tech was unable to reproduce the rattle on test drive but hears the difference between mine and the dealer's 08 and it is now in the record. They are very helpful in getting to the bottom of problems. What is inside this unit that could be rattling around?? Safety issue?? Link to comment Share on other sites More sharing options...
brus brother Posted September 29, 2008 Author Share Posted September 29, 2008 Thanks Nipper. No couldn't reproduce sound with tech in car but today isolated it to a connector coming out from the harness BELOW the ABS unit that was rattling against the chassis. A real Doh moment. I can't see what this connector is for (other than driving me nuts) as there isn't anything else in the area where it might or should be connected. So I used a zip tie and now life is good, my sanity restored. Link to comment Share on other sites More sharing options...
Olnick Posted September 29, 2008 Share Posted September 29, 2008 brus brother said: So I used a zip tie and now life is good, my sanity restored. Ahhh, it takes so little to make some people happy! (j/k--glad you found the source.) Link to comment Share on other sites More sharing options...
Buick350X Posted September 29, 2008 Share Posted September 29, 2008 Louder exhaust or better stereo system would of fixed it too Link to comment Share on other sites More sharing options...
