Scott in Bellingham Posted September 27, 2008 Share Posted September 27, 2008 got a 88 EA82 Turbo starts and runs ok when cold but shut it off when warm and it wont start again, let it sit a bit go back and it starts right up, Im not sure what to check any clues?? Link to comment Share on other sites More sharing options...
naru Posted September 27, 2008 Share Posted September 27, 2008 Leaking injector,faulty cts Link to comment Share on other sites More sharing options...
fshnidiot Posted September 27, 2008 Share Posted September 27, 2008 +1 on the CTS. Mine did that until I hardwired it in and scrapped the plug connectors. They get corroded real quick. Frank Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 27, 2008 Author Share Posted September 27, 2008 Duh whats a CTS Link to comment Share on other sites More sharing options...
fshnidiot Posted September 27, 2008 Share Posted September 27, 2008 Coolant Temp Sensor. Found on, under, or behind the intake manifold depending on which year motor. On my 86 XT Turbo it's behind the manifold on the passenger side. 2 wires leading to a plug with a small wire clip to hold it in place. There's a good write up on how to permanently fix it on the XT site. http://www.subaruXT.com Frank Link to comment Share on other sites More sharing options...
joostvdw Posted September 28, 2008 Share Posted September 28, 2008 The turbos aren't as prone to CTS failures as the sixes, so I doubt it's the CTS. Try swapping out the coil, I bet that's the problem. Coils are the same throughout the EA82 range, so you should have one laying around Link to comment Share on other sites More sharing options...
