bigo1966 Posted October 1, 2008 Share Posted October 1, 2008 Ive read about all the things i need to look out for when lifting an EA82. I cant seem to find out if there is going to be any problem with the AC on my car once its lifted? I thought i read that some time back. Thanks. Link to comment Share on other sites More sharing options...
torxxx Posted October 1, 2008 Share Posted October 1, 2008 there is a lot of hose there on the EA82 AC lines. the long line bolts to the spare tire shelf, all you'd have to do is make a cheap dropdown bracket for it. As for the other one goes I think it will be fine because you are lowering the engine and the condensor stays in the same spot so lengthing shouldnt be needed. Link to comment Share on other sites More sharing options...
bigo1966 Posted October 2, 2008 Author Share Posted October 2, 2008 Easy enough. This car also has the mechanical fan. Is there any concern with the fan after the motor is lowed however many inches? Link to comment Share on other sites More sharing options...
MorganM Posted October 3, 2008 Share Posted October 3, 2008 With a properly functioning radiator, water pump, thermostat, and radiator cap you won't need more than the electric fan. Clutch is probably worn out on that old clutch fan anyway! Also the thermoswitch in the radiator (which operates the electric fan) is prone to failure given the age of the vehicle. Most people just wire up a manual toggle switch or you can replace the thermoswitch. If you really want to run the clutch fan you'll have to either remove the fan shroud or cut the bottom half of it out so that the fan won't interfere with it. Link to comment Share on other sites More sharing options...
bratman18 Posted October 3, 2008 Share Posted October 3, 2008 With a properly functioning radiator, water pump, thermostat, and radiator cap you won't need more than the electric fan. Clutch is probably worn out on that old clutch fan anyway! Also the thermoswitch in the radiator (which operates the electric fan) is prone to failure given the age of the vehicle. Most people just wire up a manual toggle switch or you can replace the thermoswitch. If you really want to run the clutch fan you'll have to either remove the fan shroud or cut the bottom half of it out so that the fan won't interfere with it. I second that! I don't have a clutch fan on my brat, just an electric and it never gets hot. Link to comment Share on other sites More sharing options...
bigo1966 Posted October 3, 2008 Author Share Posted October 3, 2008 Off with the fan!!!!!!!!!!!!!!!! Its only robbing precious HP anyway. This is eventually going to turn into the build thread when i get lift, tires, 6lug conv etc.....So stay tuned. Link to comment Share on other sites More sharing options...
