Brake bias valve
Bias valve... is that the same thing as a Proportional valve?
Possibly try a search for Proportional valve if that is what a Bias valve is?
I have been told a proportional valve on the brakeing system goes to the lines that feed the rear brakes.
I did my rear conversion this summer but havn't had a chance to install one.. some say you don't need them
but that just opens a can of worms so do a search if the Prop. valve is the same as a Bias valve or let me know differently.
Sorry my reply doesn't clarify your question; hopefully some of this info helps in your search.
Edited by Indrid cold
As long as you will never be doing panic braking, you don't need one....
For the rest of us, it keeps the rear from locking before the front. I did a wet-pavement skid test both ways and without the valve your rear axle will pass you - I ended up facing 180 degrees out in the oncoming lane from about a 60 MPH skid. With the valve the skid is straight and tight.
I have the rear disc conversion on my brat and I have had to panic stop several times, and never has it stopped anything but dead straight even on wet or slippery surfaces! That was actually one of the things I was so impressed about after doing the conversion. I didn't change anything as far as proportioning valves nor did I add any! And I have used them with stock size and big tires.
