DaytonaTunnel Posted October 3, 2008 Share Posted October 3, 2008 I'm trying to help a friend work out a problem with his `87 GL. It was in running condition, then wouldn't start the next morning. I know Honda's have troubles with a main circut relay, do Subaru's ??? just looking for an idea where to start troubleshooting ? Thanks for any help !!! Chris Link to comment Share on other sites More sharing options...
DaytonaTunnel Posted October 4, 2008 Author Share Posted October 4, 2008 Any ideas ? Is this the right part of the forum for this question ? Link to comment Share on other sites More sharing options...
Quidam Posted October 4, 2008 Share Posted October 4, 2008 DaytonaTunnel said: Any ideas ? Is this the right part of the forum for this question ? Hi, Yes. Put a battery charger on it. Check and clean the battery connections. Let us know what happens. Doug Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 4, 2008 Share Posted October 4, 2008 We need a better description of the problem. "car won't start" is vague and most of us don't care to spend valuable time speculating. If that's all the better you can describe it then you best take it to a shop. GD Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 4, 2008 Share Posted October 4, 2008 If the motor turns over but wont start, then try spraying some starter fluid into the throttle body. if you dont have starter fluid, then carb cleaner/brake cleaner/throttle body cleaner will do. If it fires up and stalls, then you have some sort of fuel problem. If it doesnt, chances are you have no spark. Those are the first two things you need to check... fuel & spark. If the car wont even turn over, then I suggest checking the battery to make sure its not dead. Link to comment Share on other sites More sharing options...
DaytonaTunnel Posted October 5, 2008 Author Share Posted October 5, 2008 The engine turns over no problem. Just doesn't lite off. My first thought was a main relay, which is a common problem with Honda's. Didn't know if Subaru's have the same set up wiring wise ? Link to comment Share on other sites More sharing options...
Quidam Posted October 5, 2008 Share Posted October 5, 2008 DaytonaTunnel said: The engine turns over no problem. Just doesn't lite off. My first thought was a main relay, which is a common problem with Honda's. Didn't know if Subaru's have the same set up wiring wise ? Ok, talk to me. Is is carbureted, MPFI, MPFI Turbo, SPFI? Forget about any main relay for right now, k? It's fuel, or spark. Like the man said. Need more info. Doug Link to comment Share on other sites More sharing options...
brokebill Posted October 5, 2008 Share Posted October 5, 2008 not to jump to conclusions with a minimum of details, but, kinda sounds like the so very common broken timing belt. (thats the way i've had em go out before, sudden and without warning) good luck, Bill Link to comment Share on other sites More sharing options...
smelly_cat Posted October 5, 2008 Share Posted October 5, 2008 Check the wires going to coil., , They break or fall off after 20 years. pull a wire from the a plug, expose the metal , put a leather glove on, hold it a close to the block. turn it over . see a pretty blue sparK? if yes, electrical is ok sc Link to comment Share on other sites More sharing options...
DaytonaTunnel Posted October 5, 2008 Author Share Posted October 5, 2008 OK I will forget about the main relay. I know you need three things for an engine to run. So I will start with spark, then check fuel and timing events. I should of put up more info, my bad. I rump roast-u-med/was hoping there might be a common failure area in these cars. I hoped to arm myself with this info before killing 10 gallons of fuel to try and help him out. P.S. It's carbed. Link to comment Share on other sites More sharing options...
cmiller Posted November 11, 2008 Share Posted November 11, 2008 Did you ever get it running? Link to comment Share on other sites More sharing options...
ellets Posted November 11, 2008 Share Posted November 11, 2008 Pop the dist cap and see if rotor turns when you try to start. If no turn broke belt. Also check rotor and see if it is loose. Screw may be out. Link to comment Share on other sites More sharing options...
SoobieKoralli Posted November 11, 2008 Share Posted November 11, 2008 Check and make sure all the electrical is firmly connected, (EG: Plugs, plug wires on both distributor and plugs, battery, coil ETC...) if its loose it can prevent a start up. Link to comment Share on other sites More sharing options...
subiemech85 Posted November 12, 2008 Share Posted November 12, 2008 try slamming the door Link to comment Share on other sites More sharing options...
SoobieKoralli Posted November 12, 2008 Share Posted November 12, 2008 subiemech85 said: try slamming the door OMG thats funny. Sometimes I wish it were that simple, but then again you have to wonder if slamming the door makes your car work, WTF is going on? Link to comment Share on other sites More sharing options...
subiemech85 Posted November 13, 2008 Share Posted November 13, 2008 did that on the rx just after buying it and drove to ollies discount in berks county pa area try to start, NOTHING slam door, works turned out to be loose fuse link Link to comment Share on other sites More sharing options...
SoobieKoralli Posted November 13, 2008 Share Posted November 13, 2008 I will keep that in mind, if my car should suddenly stop working lol. Link to comment Share on other sites More sharing options...
