madkow007 Posted November 11, 2008 Share Posted November 11, 2008 Will the fuel injectors from a 90 leg EJ22 5 speed work in a 90 leg EJ22 auto? 2nd Q Will the front axles from a 90 leg 5 speed awd work on a 90 leg auto 2wd? Thanks for any help Link to comment Share on other sites More sharing options...
bratman18 Posted November 11, 2008 Share Posted November 11, 2008 Will the fuel injectors from a 90 leg EJ22 5 speed work in a 90 leg EJ22 auto?2nd Q Will the front axles from a 90 leg 5 speed awd work on a 90 leg auto 2wd? Thanks for any help I know that the injectors will work.....its the same motor the tranny doesn't matter and I'm pretty sure the axles are the same as long as one isn't turbo. But I'm sure someone will correct me if I'm wrong. Link to comment Share on other sites More sharing options...
davebugs Posted November 11, 2008 Share Posted November 11, 2008 I second the injectors will work. IIR I've had problems with those old injectors. I forget of the grey ones or red ones are worse. But I definately used to have issues with them. And they aren't a whole lot of fun to replace - or I never developed the knack of doing it. I do recall that hose pliers are your friend! If you're in a hurry about the axles - call the local auto parts and see if they have the same part# - or look them up online. Dave Link to comment Share on other sites More sharing options...
madkow007 Posted November 12, 2008 Author Share Posted November 12, 2008 When I replaced the ones in an auto tranny a while back...the auto parts place listed ones for auto tranny and diff ones for 5 speed and the pics looked differant, thought maybe the computer may have something to do with it. Link to comment Share on other sites More sharing options...
Snowman Posted November 12, 2008 Share Posted November 12, 2008 Axles should be compatible...most axle places list the same one for 90-99, all transmissions. The injectors are different, but may swap just fine. If you swap the whole fuel rail, you shouldn't have any trouble at all, but I can't guarantee the injectors from one can go into the other fuel rail. Link to comment Share on other sites More sharing options...
madkow007 Posted November 12, 2008 Author Share Posted November 12, 2008 Sounds good...I can do the whole fuel rail. Now to see if one of these has a good axle. Thanks for the replys. Link to comment Share on other sites More sharing options...
idosubaru Posted November 12, 2008 Share Posted November 12, 2008 yep the injectors/rail and axles interchange just fine. the engines are identical, probably only some vaccum line differences due to auto/manual. Link to comment Share on other sites More sharing options...
SoobieKoralli Posted November 12, 2008 Share Posted November 12, 2008 He asked cause when he looked it up to 'order' injectors, the site asked him if it was a manual or automatic. Thats what threw us. My Frankensoob will have life yet... Link to comment Share on other sites More sharing options...
