My wifes 95' has a "water pipe" made of aluminum that
has started to disintegrate where the radiator hose attaches.
The local dealer wants $260 for one!! Plus another $20 for
the 2 O rings needed.
The dealer called it either a water pipe or crossover tube.
Any ideas on a better source to get one?? I am hesitant to
get a used one. If this one is rotting away I would imagine
it's a common problem.
buy a used one, there's plenty out there that are still in great shape. i have a 97 impreza, 96 legacy, picked up a 97 and 95 legacy this summer for friend/relative and all had the original pipes in good condition (and this is the rust belt).
if you buy one from someone here (like that guy just offered), then you can ask them the condition or check out a photo. any yard you get one from should be able to as well.
I have emailed the following link to my wife for part
ID to be sure.
It is labled as "water pipe". Is this the one you guys
are talking about??
This one is new and only $133 new........ better than
the local dealer to be sure.
http://fargovalley.hondasubaruparts.com/partlocator/index.cfm?action=getJointLocator&siteid=215050&chapter=&Sectionids=0,2308&groupid=51823&subgroupid=3817&componentid=0&make=32&model=Legacy&year=1995&graphicID=7521045&callout=17&catalogid=2&displayCatalogid=0
I've seen minor pitting in a lot that I've worked on... never to the point that it was a problem though. I suppose that since that's one of the hottest points in the cooling system, any corrosive or otherwise unfriendly chemical reactions would occur faster there than somewhere else.
