njdrsubaru Posted November 13, 2008 Share Posted November 13, 2008 i have done some research here and i have found a few similar threads but none that can help with my problem... just a little over a month ago, my legacy developed "sticky" steering, that is when you are driving about 10 to 50 mph and you try to turn to left or right it feels like there is a resistance almost like someone holding your steering wheel. Also after making turns the steering wheel does not go back to the original position as it should... now i have both new ball joints, both new inner tie rods, new PS pump and no leaks from the steering rack. keep in mind that the problem is intermittent and not a everyday thing... let me hear your thoughts before i start replacing the outer tie rods thanks in advance Link to comment Share on other sites More sharing options...
bratman18 Posted November 13, 2008 Share Posted November 13, 2008 njdrsubaru said: i have done some research here and i have found a few similar threads but none that can help with my problem... just a little over a month ago, my legacy developed "sticky" steering, that is when you are driving about 10 to 50 mph and you try to turn to left or right it feels like there is a resistance almost like someone holding your steering wheel. Also after making turns the steering wheel does not go back to the original position as it should... now i have both new ball joints, both new inner tie rods, new PS pump and no leaks from the steering rack. keep in mind that the problem is intermittent and not a everyday thing... let me hear your thoughts before i start replacing the outer tie rods thanks in advance Maybe cv's? I had a cv that wasn't making any real noise and the boot wasn't ripped but it would bind up every now and then? But your sounds a little different. :-\ Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 13, 2008 Author Share Posted November 13, 2008 oh yeah i forgot to mention that, the CV on the drivers side is making some noise but no ripped boot... Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 13, 2008 Author Share Posted November 13, 2008 hmm if the universal on the steering column is bad, where do i get a new one of those? dealer? Link to comment Share on other sites More sharing options...
bratman18 Posted November 13, 2008 Share Posted November 13, 2008 njdrsubaru said: hmm if the universal on the steering column is bad, where do i get a new one of those? dealer? Yup probably one of the few places you could pick one up! I did forget about that!! I've seen a few of those go bad so I bet nippers right!!! Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 13, 2008 Author Share Posted November 13, 2008 why would it get better in some days and go bad again in others? Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 14, 2008 Author Share Posted November 14, 2008 after chatting with nipper tonight i have decided to bleed the system and change the drivers side outer tierod and see if that makes it better, i'll keep you all informed how it turns out Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 14, 2008 Author Share Posted November 14, 2008 lol i didnt say u said that, i said "i have decided" i didnt take your opinion, i made up my own conclusions sorry :grin: Link to comment Share on other sites More sharing options...
njdrsubaru Posted November 14, 2008 Author Share Posted November 14, 2008 nope, :grin: Link to comment Share on other sites More sharing options...
