msmithmmx Posted November 14, 2008 Share Posted November 14, 2008 Ok, I am a day away from finishing my 7 month head gasket job. What is the best way to get some oil circulating so I can prevent a dry start. I am thinking I should not just start cranking it. Any ideas? Quote Link to comment Share on other sites More sharing options...
EvilDead Posted November 14, 2008 Share Posted November 14, 2008 Maybe hand crank it a bit? I wish Subaru offered pre-oiler kits. Quote Link to comment Share on other sites More sharing options...
svxpert Posted November 14, 2008 Share Posted November 14, 2008 unplug the plugwires and turn the key over for a few seconds to get the oil circulating. Quote Link to comment Share on other sites More sharing options...
EvilDead Posted November 14, 2008 Share Posted November 14, 2008 unplug the plugwires and turn the key over for a few seconds to get the oil circulating. Or just the one coil plug wire? Quote Link to comment Share on other sites More sharing options...
davebugs Posted November 14, 2008 Share Posted November 14, 2008 I fill the filter, a couple times it keeps sucking it up. Unplug the coil pack (why do 4 wires and possibly have that spark jumping around when you can eliminate the spark?). Crank a few times for a few seconds (helps with fuel pressure as well). Plug in coil pack, it should fire. I just let them idle for several minutes before increasing the RPM's. Dave Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted November 14, 2008 Share Posted November 14, 2008 perhaps you can turn the pump with timing belt off Quote Link to comment Share on other sites More sharing options...
Setright Posted November 14, 2008 Share Posted November 14, 2008 OR, unplug the crankshaft sensor.....turn ignition key for 20 seconds...wait half a minute....20 seconds.... Or whatever rythym suits you, just don't stress your starter motor too much Quote Link to comment Share on other sites More sharing options...
2.5GL Posted November 14, 2008 Share Posted November 14, 2008 OR, unplug the crankshaft sensor.....turn ignition key for 20 seconds...wait half a minute....20 seconds.... Or whatever rythym suits you, just don't stress your starter motor too much Then you have to clear memory for a crank sensor code... Just unplug the coil. Crank until the oil light goes off, or about 1 minute. The starter will take it. Heck, with a broken timing belt and some tape on the clutch switch, you can drive 'em around with the starter! Quote Link to comment Share on other sites More sharing options...
Skip Posted November 14, 2008 Share Posted November 14, 2008 cold engine: fuel injection = rich lotta gas on the bare cyl walls Think I'd unplug the injectors or fuel pump to prevent this. Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted November 15, 2008 Share Posted November 15, 2008 remove the igniton or fuel pump fuse and crank away!! Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted November 15, 2008 Author Share Posted November 15, 2008 Ok, Its done.. It started up and runs..... BUT, I have a VERY noisy Lifter, its clicking REAL bad. It has Hydraulic lifters. I also feel like it has no accelerating power. Anyone ever see this after a head gasket replacement. Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted November 16, 2008 Share Posted November 16, 2008 Ok, Its done.. It started up and runs..... BUT, I have a VERY noisy Lifter, its clicking REAL bad. It has Hydraulic lifters. I also feel like it has no accelerating power. Anyone ever see this after a head gasket replacement. Yes , it probably just needs to pump up. Run it for awhile it should get better. Could also try draining a qt. of oil and replacing it with qt of K-1 run it 10 15 min. Change the oil / filter. Quote Link to comment Share on other sites More sharing options...
