Numbchux Posted May 6, 2009 Author Share Posted May 6, 2009 bought this on Sunday so I can hone my own cylinders (and a ring compressor): some parts NPR piston rings ACL main and rod bearings PCI timing kit GMB new water pump head bolts and an OEM engine gasket set another part showed up last week, it said this on it Monday's progress. bolted the case halves together: rear main seal in oil and water pumps installed. pistons, as well as coolant bridge, and wrist-pin access plugs. once again, not much to do until more parts come. this time waiting on the ported/polished heads with reground cams to arrive from Delta. Quote Link to comment Share on other sites More sharing options...
Subarutex Posted May 6, 2009 Share Posted May 6, 2009 Thats hot chux. That tranny... is it the holy grail? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 7, 2009 Author Share Posted May 7, 2009 it might be.....it looks kinda funny Quote Link to comment Share on other sites More sharing options...
bratman18 Posted May 7, 2009 Share Posted May 7, 2009 Ahhh, so you're the one that got that from Zap. Nice!!! Can't wait to hear how it goes once it's in the car!! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted June 16, 2009 Author Share Posted June 16, 2009 the car is for sale, but the build continues. couple more parts arrived: I had pretty much giving up finding a subaru AWIC......then i got a tip from someone at the Nemadji 1 rally, and now I have one. I'll have to do something about that sticker though....."Turbo" just doesn't fit anymore and then these pretties: HUGE thanks to Ken and everyone at Delta for their work on the project. Heads were mildly ported/polished, rebuilt, and cams reground for torque. They're gorgeous! I was thinking about taking them downstairs, and bolting them up to the motor.....but I think I'll put them on the shelf here in the living room Toll Free: 1.800.562.5500 Quote Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 16, 2009 Share Posted June 16, 2009 awesome my friend awesome.. Kaz Quote Link to comment Share on other sites More sharing options...
cameron 1 Posted June 18, 2009 Share Posted June 18, 2009 holy sh@# thats awsome what kind of power will it put out Quote Link to comment Share on other sites More sharing options...
Numbchux Posted June 18, 2009 Author Share Posted June 18, 2009 holy sh@# thats awsome what kind of power will it put out with stock pulleys, it will probably boost about 4-5psi. which is pretty conservative, considering the rest of the build. But, I still expect about 150awhp. with a larger crank pulley, I should be able to bring it up to about 8-9psi before maxing out these injectors (stock turbo legacy), at which point, I don't think 200awhp is out of the question. then with larger injectors. I could step the boost up a bit more, something like 10-11psi before I have to start worrying about the setup with this compression. I don't plan to go to this point at this compression. once I max out the injectors, my next step will be a whole new engine. probably an EJ255/257 semi-closed shortblock, and EJ25D heads/intake. but that's all a couple years off. might just skip it and go diesel Quote Link to comment Share on other sites More sharing options...
Zefy Posted June 20, 2009 Share Posted June 20, 2009 awesome build. do you have some close up pics of the PnP setup that delta did? Very interested in how it looks. the ej22 heads are so piddly i'm curious to see how much porting can be done. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 7, 2009 Author Share Posted July 7, 2009 ^forgot to take some closeups. I'll try to remember when I have the intake mani off. This was a pretty mild porting job, mostly just a casting cleanup. but they did sharpen up the splitters on the intake sides nicely. well. I bolted them to the motor. and then put an intake manifold on it..... and then I found some other random junk around the basement (wound up with a box and the center case section from a legacy trans...) to hold the SC and IC where they would wind up to plan my intake tract. Yea, when the new shell arrives, it probably won't be long before it's boosting! Quote Link to comment Share on other sites More sharing options...
reddevil Posted July 10, 2009 Share Posted July 10, 2009 Looking good! I managed about 150 whp @ 8? psi and about 190ish @ 12 psi. Quote Link to comment Share on other sites More sharing options...
JackV Posted August 17, 2009 Share Posted August 17, 2009 I'm amazed right now, I love this build... Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 18, 2009 Author Share Posted August 18, 2009 Looking good! I managed about 150 whp @ 8? psi and about 190ish @ 12 psi. hmmmm...maybe my estimates were a bit high. that's alright, those numbers are perfectly acceptable, and with the other mods I'm doing, the torque curve should be positively sexy I'm amazed right now, I love this build... Thanks! I may have decided on a shell to install it in. I was planning on buying a clean PNW coupe shell sometime next summer and painting it, but since the accident in my XT6 last week, I'm thinking it'll be cheaper to pull the frame out and fix a couple rust spots on it than get my hands on a new shell. and since I was already planning body work and paint..... not much for updates lately. except my girlfriend bought me a set of Phenolic intake manifold spacers for my birthday a few weeks ago! Quote Link to comment Share on other sites More sharing options...
zukiru Posted August 18, 2009 Share Posted August 18, 2009 sweet this is going in the 6?? awesome... of course it won't be a 6 anymore, huh? Quote Link to comment Share on other sites More sharing options...
subaruguru Posted June 2, 2011 Share Posted June 2, 2011 watching this thread Cheers R. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted June 3, 2011 Author Share Posted June 3, 2011 BYOB. you'll need it. only thing I still own from this build is the Link ECU. Engine was put in a t-leg ice racer....and blown. blower and AWIC were ebayed. heads sold on rs25. transmission sold. Wagon sold. XT6 will be for sale as soon as the body damage is repaired. Never talked my uncle into selling the 914. I'm done with street cars, for now at least. my modifying money goes into the 4runner and brat. I like the way my celica handles better than the subarus. and it gets better mileage.... and most of my time goes to the Ziptie Rally cars. Quote Link to comment Share on other sites More sharing options...
subaruguru Posted June 3, 2011 Share Posted June 3, 2011 right should have checked the post date lol. Cheers R. Quote Link to comment Share on other sites More sharing options...
