5SPD D/R transmission into '92 Loyale project
cmiller
Well this afternoon I start the swap process. :headbang: I'm disconnecting and hopefully pulling the 5SPD S/R out of the Loyale by tonight. Then tomorrow put in the 5SPD D/R into it and road test. I will post pics as things roll along.
picture.php?albumid=41&pictureid=257
here's the new transmission waiting to go in the Loyale. I put in new seals, new shift bushings, clutch bearing, dust boot, and tranny mounts. Can't wait to have it in!!
Hi,
This very swap is in my near future. What year DR tranny are you using? I may use a '86 or an '89.
Doug
I pulled mine out of a '88 GL from the wrecking yard. Its in great shape and the donor car has 80,000 less miles on it than my Loyale.
AND IT BEGINS!:clap:
picture.php?albumid=41&pictureid=259
up on stands and front tires off.
picture.php?albumid=41&pictureid=258
pulled the shifter and console out and moved the carpet out of the way. Next I'm disconnecting as much as I can on top of the tranny from under the hood. Then move the exhaust and drive line out of the way. More pics on the way!:popcorn:
Edited by cmiller
picture.php?albumid=41&pictureid=265
Pile of parts, drive shaft, skid plate, exhaust, etc...
picture.php?albumid=41&pictureid=266
Everything disconnected from the transmission, driveline, front axels, etc... Now ready to drop the transmission, but I think its time to call it a night. :drunk:
Quick question, what are people doing with the two extra vacuum lines from the push button 4WD after they are disconnected? Don't really need them with the new transmission.
picture.php?albumid=41&pictureid=267
Old transmission out...
picture.php?albumid=41&pictureid=269
ready for the dual range
picture.php?albumid=41&pictureid=268
putting in the dual range
picture.php?albumid=41&pictureid=270
shift linkage and interior all buttoned up. Everything went in easy and without a hitch. :clap:
I just plugged up the vacuum lines from the old tranny, also I kept the Loyale shifter with the button. I dunno what to hook up to the switch. Any ideas? passenger ejector seat? air horn?...:brow:
Did the road test and man what a difference in 4 low!:headbang: Can't wait for some snow!
nice work:drunk:
Hows this Sunday for wheelin ... Team CF and I are always out and about...let's go wheelin' !
Don't forget the HP X-mas tree run..!
I need to do the swap myself as my 4spd has a bad 3rd gear syncro and no hi range..
For the switch I would make it the turbo boost(Blower) switch ya know like the madmax intercepter...lol
Edited by scoobyclimbs
nice work:drunk:
Nice!
I have to work this weekend. But I really want to see your new hatch. The tranny swap was much needed. Next I have to figure out a front bumper.
So I have an '85 with the POS 3 speed auto so I need a swap of this kind. I am curious if anyone knows about the peddle assembly and if any cutting of the firewall would be needed to fit a clutch peddle?
Thanks for any input available and congrats on the upgrade..
No cutting necessary.
Just make sure you get all the parts needed for the swap.
Peddle assembly, clutch cable.
Complete running gear.
Make sure the rear diff ratio you get matches the tranny (3.9 for a 5spd D/R non turbo)
I did this swap as well and changed the whole dash board and harness as well and I also stole the manual seat belts out of the donor car as well!
  • 3 months later...
It would with some mod, but are you talking about the 4 spd d/r? If so it's not worth it, the 5 spd is much stronger
yes the 4 spd d/r, 83 - 87, i was just looking for the low range, off road. how different are they? the gear ratios appear to be close. is the loyale too heavy?
mostly i was wondering about the bell housing bolts. what kind of mods besides the hi low lever, trans mount, shifter?
is it possible/ practical to swap the 'dual range' section on to the loyale 5 speed??
Edited by johnceggleston
