how to adjust EA82t idle...
my WAG is the line from the IAC is split or cracked at
one end causing a vacuum leak.
Have a look at it while you check for the coolant leak.
Nobody you know messed with the throttle stop scew - eh?
Check out your aux air valve for proper functionhttp://www.ch601.org/engines.htm
It sits on top of the thermostat housing and functions as the choke. If it is not working properly or the hose to the air duct is bad your " choke " is on all the time.
Edited by subuaroodude
