EA-82 Exhaust Manifold Gaskets
The ones on the right are from NAPA from about a year ago. The bottom metal is more like OEM. The others are recent multi layer from Fel Pro.
I have used both sizes on the manifold to head interface on a EA-82.
Of course, I belt sand the flange on the pipe flat. They'll all work if you do that.
Doug
The top one on the left, and the middle one on the right are manifold gaskets. Both are inferior types but the top left one at least has a combustion seal ring.
The others are for the mid-pipe to exhaust pipe flange mating right before the rear axle. It's not as critical that they have the seal ring in them but all the OEM one's do.
The OEM gaskets are best and they are similar to the bottom right style - graphite/metal with a seal ring.
Hi,
Good Morning all. Last two Y pipes I've done, I used Beck Arney. Slide them over the studs and they stay there. Nice. I don't have any on hand to take pics of because I used them:). Just a wide variety of materials and construction out there.
Doug
