subiemech85 Posted November 18, 2008 Share Posted November 18, 2008 looking for ACTUAL resistance values for the resistors in the resistor pack for the blower motor speed control would also like to know the resistance value of the blower motor itself trying to calculate watts, etc. to over-build a replacement system, overkill search has come up with little info, also not sure of the accuracy http://www.ultimatesubaru.org/forum/showthread.php?t=64761&highlight=resistor+pack&page=6 # 58 gave some info, but a little hard to follow when values entered in spreadsheet, stuff is easier to see chart is at http://www.cardomain.com/ride/3192778 Link to comment Share on other sites More sharing options...
Cougar Posted November 18, 2008 Share Posted November 18, 2008 If you are planning to use ceramic resistors I think you will find that they will make the size of the mod to be pretty large. You may need 10 to 20 watt sizes. Link to comment Share on other sites More sharing options...
mikeshoup Posted November 18, 2008 Share Posted November 18, 2008 After looking at the post, http://www.ultimatesubaru.org/forum/showpost.php?p=537704&postcount=58 Looks like you need three resistors: 0.46 ohms, 50W 0.6 ohms, 22W 1 ohms, 16W I'm mildly interested in this as my blower only works on speeds 3 and 4. I may just go scavenging a junkyard for a good one. Link to comment Share on other sites More sharing options...
Cougar Posted November 18, 2008 Share Posted November 18, 2008 That is even more wattage than I thought it would be. Maybe using resistors that size a seat heater could be designed. LOL. Summertime use may not be so pleasent though. Darn, back to the drawing board. Link to comment Share on other sites More sharing options...
edrach Posted November 19, 2008 Share Posted November 19, 2008 That is even more wattage than I thought it would be. Maybe using resistors that size a seat heater could be designed. LOL. Summertime use may not be so pleasent though. Darn, back to the drawing board.This problem has been beaten to death pretty often. The final conclusion is that the wattage is pretty significant; that's why Fuji uses the blower to run air over the resistor block to dissipate some of the heat. Best bet is to hit the pull a part yards and pull one of these until you find a good one (been there, done that). Good luck. Link to comment Share on other sites More sharing options...
msteel Posted November 19, 2008 Share Posted November 19, 2008 Best bet is to hit the pull a part yards and pull one of these until you find a good one (been there, done that). Good luck. Also, if it is worth it for you to buy new, there are replacements available. Rockauto.com has 5 brands including Subaru for $38.79 to $55.79. Link to comment Share on other sites More sharing options...
zstalker Posted November 19, 2008 Share Posted November 19, 2008 SOA part number for the EA81 HVAC blower resistor is 772083010. It can be found online for about $35 plus shipping. Walking into your local Subaru dealership would be about $50, so if time if a factor, a $15 premium isn't terrible. but then again...you'd have to wait till they get their order in too, so I guess it's not really quicker, is it? (If, judging by your avatar, you're a Subaru tech as well, you can probably get it pretty cheap through work anyways.) Link to comment Share on other sites More sharing options...
DaveT Posted November 19, 2008 Share Posted November 19, 2008 After looking at the post, http://www.ultimatesubaru.org/forum/showpost.php?p=537704&postcount=58 Looks like you need three resistors: 0.46 ohms, 50W 0.6 ohms, 22W 1 ohms, 16W This is correct. Also the reason they are air cooled by the blower. Dave Link to comment Share on other sites More sharing options...
subiemech85 Posted November 19, 2008 Author Share Posted November 19, 2008 the reason I requested the ACTUAL resistance values is because... 1. from reading post # 58, it was not clear if the values were after his repair 2. I will be ordering high watt wire wound aluminum case axial lead bolt on flange mount 1% resistors, cost less than $6 each made by Huntington Electric Inc., sold by Digi-Key Corporation, with a data sheet @ http://www.heiresistors.com/PDF/TMC%20Spec.pdf , that will be bolted to the main blower duct just after the blower motor so the fan will keep them cool hopefully a durable solution to the issue Link to comment Share on other sites More sharing options...
DaveT Posted November 19, 2008 Share Posted November 19, 2008 That (#58) was my post. The only non stock resistor is the 1 ohm for the slowest speed. It's close, but just a bit slower than stock for the lowest setting. I have not had one of my modified ones fail. I've been running EA82 wagons since about 1988. I'm not sure why the list / columns got all messed up. I don't remember them that way originally. Probably +- 10% on the values won't make the blower speeds way off. I would bolt those aluminum resistors to a plate (not just the plastic) also. The power ratings assume a heatsink. Link to comment Share on other sites More sharing options...
subiemech85 Posted November 19, 2008 Author Share Posted November 19, 2008 I figured the ambient temp will be low enough to not worry about extra heat sink with the active cooling from the fan, but perhaps a piece of diamond tread aluminum holding the resistors away from the box wall 1/2" + may work better will be using the spare blower box as the test bed for R/D purposes Link to comment Share on other sites More sharing options...
Davalos Posted December 2, 2008 Share Posted December 2, 2008 I have a maybe dumb but hopefully related problem with my blower: sometimes, it just won't work, at any speed setting. No rhyme or reason as to when, but it just plain doesn't work for a driving session or two ... then, like magic, it 'decides' to work again. SOMETIMES, when the blower motor speed is @ "high", there is about a 2-3 second delay between the time the car starts and the time the blower motor kicks in. When it works, all 3 speeds work. When it doesn't work, no speeds at all work. Not sure where to start. Are we talking Relay? Resistor? Motor? Link to comment Share on other sites More sharing options...
DaveT Posted December 3, 2008 Share Posted December 3, 2008 Not resistor. Possibly the contact that feeds power to the switch. There are a few others in the wiring also. Possibly motor. I guess I'd start with a voltmeter check on the 2 leads of the motor. Lead to lead, lead 1 to ground, lead 2 to ground. That will tell a lot. While it is not working properly. Link to comment Share on other sites More sharing options...
joostvdw Posted December 4, 2008 Share Posted December 4, 2008 I'm working on this same problem as we speak, since it's winter over here and when it's winter time, it's wet, so I really need the blower working properly. So I built myself a PWM motor controller, and am currently modding the dash switch to accept the potentiometer, so I will have full 0%-100% control over the fan Will post some pictures when it's done. Link to comment Share on other sites More sharing options...
ballitch Posted December 5, 2008 Share Posted December 5, 2008 Want more info, have had my fan hooked up to a toggle switch for 3 years. And I tried the pull a part yards, pulled all the speed selectors and brought them all back. ....maybe it was the power feed to the speed selcetor switch...:-\ ~Josh~ Link to comment Share on other sites More sharing options...
