quicsam Posted November 19, 2008 Share Posted November 19, 2008 All of my dash warning lights are dim not bright (on). The brake light is off. Alternator belt is snug and shunt to ground is good. Any suggestions? Link to comment Share on other sites More sharing options...
bratman18 Posted November 19, 2008 Share Posted November 19, 2008 quicsam said: All of my dash warning lights are dim not bright (on). The brake light is off. Alternator belt is snug and shunt to ground is good. Any suggestions? I say that your alternator is failing Link to comment Share on other sites More sharing options...
quicsam Posted November 19, 2008 Author Share Posted November 19, 2008 We just replaced the hose under the alternator. We got coolant in the alternator. Do you think it will dry? Link to comment Share on other sites More sharing options...
cobcob Posted November 19, 2008 Share Posted November 19, 2008 could have shorted internally... or the VR is shot. Check your voltage at the battery with the engine running. Rev the engine up and see if the voltage goes over 14.7 (nominal VR setting) if it keeps rising then your problem is there. If it doesn't go up from a baseline of approx 12v then your alt isn't putting out. Link to comment Share on other sites More sharing options...
bheinen74 Posted November 19, 2008 Share Posted November 19, 2008 sometimes, the most important things are left out in posts. more info the better. quicsam said: We just replaced the hose under the alternator. We got coolant in the alternator. Do you think it will dry? Link to comment Share on other sites More sharing options...
Durania Posted November 19, 2008 Share Posted November 19, 2008 Replace your alternator. Do it before you get stranded on the side of the road. Link to comment Share on other sites More sharing options...
zyewdall Posted November 20, 2008 Share Posted November 20, 2008 Yeah -- measure your voltage -- if it's below 13.5 or so replace the alt -- I bet the alternator is not charging for some reason, as this is the classic display you see when it fails. For some reason... Link to comment Share on other sites More sharing options...
edrach Posted November 20, 2008 Share Posted November 20, 2008 Typical symptom of diode trio failure in the alternator. Replace it with a wrecking yard one or have it rebuilt by someone local. Link to comment Share on other sites More sharing options...
edrach Posted November 20, 2008 Share Posted November 20, 2008 quicsam said: All of my dash warning lights are dim not bright (on). The brake light is off. Alternator belt is snug and shunt to ground is good. Any suggestions? Which car; I likely have a working alternator for you. Link to comment Share on other sites More sharing options...
quicsam Posted November 20, 2008 Author Share Posted November 20, 2008 Thanks cobcob...all dash lights are back to the out position. Alternator VR was out. Quicsam Still have Check engine light. Disconnected battery to clear CE light. I get no long flash an 1 short flash. Haynes manual said it is Designation codes MPFI systems code 01 (MT, 49 States and Canada vehicle.) I still have a random miss during idle that sometimes shows up as slight or rough at idle. Link to comment Share on other sites More sharing options...
