SubaruJawn Posted January 19, 2010 Author Share Posted January 19, 2010 If you want to know what's the biggest tire you can put on there with out any cutting or beating, you need to measure the distance from the center of each hub to the edge of the wheel wells. This dimension will be the radius, and you want to make sure you get a tire that won't rub on bumps or turns. Your formula for tire size is totally wrong, because the wheel wells don't automatically widen when you add the lift and because the center of the hub at stock is way up in the wheel well. You have to measure to know, every vehicle is different. Other than that, it looks good with the outback struts! -Bill mine was no formula. it was just a guess. but yeah i'll do that and find out how big i can go. Link to comment Share on other sites More sharing options...
SubaruJawn Posted January 19, 2010 Author Share Posted January 19, 2010 (edited) Nevermind Edited January 19, 2010 by SubaruJawn Link to comment Share on other sites More sharing options...
SubaruJawn Posted January 26, 2010 Author Share Posted January 26, 2010 ok so i finally measured the Distance between the hub to the Wheel Well 13 1/2" so i can go 26" and still have 1" Clearance for the Bump & Jumps. as of now without outback Trailing Arm bracket. Link to comment Share on other sites More sharing options...
subaruloverbrad Posted January 27, 2010 Share Posted January 27, 2010 i still stick firm to you needing 15" grand am gt steel wheels trust me! Link to comment Share on other sites More sharing options...
patinoly Posted July 18, 2011 Share Posted July 18, 2011 I am lifting a 93 Legacy wagon. Seems 96-99 outback struts are the way to go. I have also heard a couple of people mention forester struts. What all would that entail? What year parts would work? Or just easier to go outback? Link to comment Share on other sites More sharing options...
