JT95 Posted November 21, 2008 Share Posted November 21, 2008 Is there a trick to removing the shift lever knob/cover off an A/T stick in a 95-99 Legacy? I was wanting to take one off a car that had a leather shift lever and put it on a car without, but when I took out the two little screws on the sides, the cover didn't want to lift off the lever. Am I missing a trick to getting them off? Does it not just slide up and off? Obviously, I don't want to break either of them... Link to comment Share on other sites More sharing options...
mwatt Posted November 21, 2008 Share Posted November 21, 2008 Factory shop manual for my '98 Legacy shows a "U" shaped clip on the underside of the shift handle push-button that must be removed, then the shifter release button comes out of the handle, then remove the two screws, then pull shifter handle off. We also have a '99 Legacy---I walked out into the garage and that car does not have any "clip" holding the shifter release button....so I don't know if there was some design change between '98 and '99...... Link to comment Share on other sites More sharing options...
