The Dude Abides Posted November 22, 2008 Share Posted November 22, 2008 For the life of me i can figure out where the hell this thing is leaking from and why it only does it sometimes. A few weeks ago i was geting puddles in the middle, then tonight it was on the left. And they all stop after a while. Running, cold, hot it doesnt matter. I wish i just knew where the freekin problem was so i can plan my attack. Its got 200 thou on teh clock so take your pick, rotten hoses, bad radiator, leaky gaskets. Who the hell knows. Im about to try and take a loan out to buy someother car. I cant have this thing let me down man. If i miss one more day before the end of the year i get canned. Cummon suby gods, rain gifts on me. Link to comment Share on other sites More sharing options...
subiemech85 Posted November 22, 2008 Share Posted November 22, 2008 hardest leak to find list: heater hoses, abraided by clutch lever, impossible to see rubbing little booger manifold hoses waterpump hoses rad drain cock and sensors rad cap rad "header" leaks leaks between hose and pipe Link to comment Share on other sites More sharing options...
MilesFox Posted November 22, 2008 Share Posted November 22, 2008 look at the hose between the block and the manifold. usually this leak will dry up as fast as it leaks, but will drip now and again before the block heats up. sometimes the coolant will run off the back of the motor or puddle up in one of the spark plig castings. check the water pipe o-ring where the lower radiator hose connects. if it leaks there it drips elsewhere on the bottom. you can pop the water pipe off by removing the 12mm bolt where the ground wire is. real easy to fix if that's the problem. Link to comment Share on other sites More sharing options...
Subarule Posted November 22, 2008 Share Posted November 22, 2008 I had my original ('86) thermostat replaced recently, just because I thought it was time to) and discovered that the old one was cracked and leaking coolant. Just some more input for ya'. Link to comment Share on other sites More sharing options...
86HatchShelby Posted November 22, 2008 Share Posted November 22, 2008 I have this exact same problem mine is random sometimes it leaks hardcore, other times not at all Link to comment Share on other sites More sharing options...
The Dude Abides Posted November 22, 2008 Author Share Posted November 22, 2008 I could definately use a thermastat replacement and probally a pcv valve as well. Anyone got oem ones Link to comment Share on other sites More sharing options...
