ron2368 Posted November 22, 2008 Share Posted November 22, 2008 I got this car recently and want to change the oil myself but I cant fit under the car. It seems so low I wanted to know if I can drive it up a set of ramps, saw a set at PEP boys? Other than oil and filter , any other tools needed, I looked under it and cant hardly see anything. For the winter should I stick with synthetic? thanks As a side note, even though oil/gas prices have plummeted why is a quart of oil nearly 3 dollars:mad: Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 22, 2008 Share Posted November 22, 2008 if u cant get ramps under it dig a pit in your back yard jk just use a jack and some jack stands.. motor oil probably wont drop but gas prices im sure dropped because of elections Quote Link to comment Share on other sites More sharing options...
shimonmor Posted November 22, 2008 Share Posted November 22, 2008 Yeah, it's a pain. I have a set of ramps that I use on my 06 OBW. But I'm to the point now that I don't even bother with the ramps. I have a Fumoto valve on the pan so no more drain bolts to deal with and the only hard part is the filter because it's hidden up between two runs of the exhaust manifold and I always burn my hand on the heat shield. You probably want to get one of those oil filter wrenches you can stick on the end of extension for a ratchet (see photo). Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 22, 2008 Share Posted November 22, 2008 Yeah I have a real hard time using ramps on my 00 RS! It rubs a little on the bottom of the bumper cover because it's so low! It IS a pain!! Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 23, 2008 Share Posted November 23, 2008 I use a good scissor jack that I got from a wrecking yard. It came from an Audi. It is a much larger and stronger jack than the one that comes with the Subie. Jacks easily right behind the passanger front wheel. Gives sufficient room to drain the oil and replace the oil filter. If using a scissor jack, be sure to chalk the road wheels to prevent the car from rolling even a little bit, and applying the hand brake. Nothing dumber then getting injured from a car rolling off a jack. Quote Link to comment Share on other sites More sharing options...
