Brown_Muscle Posted November 23, 2008 Share Posted November 23, 2008 are there any rear sway bars i can install on my 84 GL that would come off of any subarus that might be in the junkyard? Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 23, 2008 Share Posted November 23, 2008 yes but you'll have to weld tabs on i believe to hold the sway bar... rx's had a rear sway bar you could use but you have to cut it down Quote Link to comment Share on other sites More sharing options...
Brown_Muscle Posted November 23, 2008 Author Share Posted November 23, 2008 ah, id be looking for direct bolt on, haha, ok thanks, ill look into that for a later project tho. Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted November 23, 2008 Share Posted November 23, 2008 you might be able to find one on a ea81 turbo vehicle.... but im not sure and the chances of finding one are slim Quote Link to comment Share on other sites More sharing options...
hatchsub Posted November 24, 2008 Share Posted November 24, 2008 No EA series car came with a rear sway bar (this includes turbos). The only way you are going to be able to make it work on a budget is to get either a RX rear sway bar or a XT6 sway bar (this one is a bit thicker than the RX). Both of these options mean you have to cut the mounting points off the parts car and have them welded to your trailing arms. You will also have to trim the XT6 bar down some to fit the narrower chassis (not sure if this is the same for the RX...assume it is). I have an XT6 bar on my sedan and i can say that it cuts down on body role a good deal. If your looking for handling you might also want to upgrade your front sway to a EA81T bar along with the springs from the same car. Good luck. Quote Link to comment Share on other sites More sharing options...
Brown_Muscle Posted November 24, 2008 Author Share Posted November 24, 2008 I'm not sure im looking into anything that in depth yet, however If your looking for handling you might also want to upgrade your front sway to a EA81T bar along with the springs from the same car. Good luck. if i do find a turbo edition car i will definitely be grabbing those! Quote Link to comment Share on other sites More sharing options...
