Runs good on boost only
The 86 t-wagon I picked up will only run well once the turbo spools up. It idles ok, a little rough, but not bad. It misfires and stumbles when you're driving it untill the boost comes, then it runs nice and smooth and pulls pretty hard all the way through the redline alarm.
When I changed the oil, there was a lot of gasoline dilution. Like mabe an extra half-quart worth of gas mixed in. It had sat for 4-5 years before I got it, so i'm wondering if mabe an injector is leaking? Though I would think that would still cause problems under boost?
It's such a stark contrast between on and off boost engine behavior. Makes me think the pcm isn't seeing something it should be, and mabe thinks the engine is on boost all the time?
You have at least one bad fuel injector.
While idling, pull the spark plug wires one at a time. When you pull a wire and "shut down" that cylinder, it the idle changes, gets worse, then that cylinder was fine. If you pull a plug wire and the idle DOES NOT change, you found the bad cylinder. That injector for that cylinder is bad.
Get a used one to get you by, but get new ones or have yours rebuilt later.
Take your time removing the old injector. Those little screws that hold them on break easily. Spray them with penetrating oil several times before you tear into it.
I had an 86 turbo three door that had the same thing wrong with it.
Good luck
