EA81t front sway bar diameter
Has anyone put a caliper or have measurements in a book for what this is supposed to be? Reason i ask is im going to to get poly bushings if i can for this bar so that when it gets here i can just throw it all in and go. I might only be able to get poly bushings for the part that connects to the bottom of the car and not the suspension itself however. If memory serves that bushings attaching the bar to the suspension are weird.
0.89 hundredths on the turbo one.
0.79 hundredths on the regular one.
I took this measurement off the bar I shipped to you,Steve.
By the way,I sent it "standard mail" USPS,days ago.
It should be there at your place this week.
Edited by markjw
I will let you know shortly. They are stiffer springs and slightly lower (if you use the EA81T springs with 2wd struts you will lower your car). The sway bar is slightly thicker. All in all it should stiffen up the handling in front. I will report back once i actually bolt it all together.
