question about mufflers
  86HatchShelby said:
edit:
why would you want a muffler on it?
I have a Cherry Bomb Glass Pack...
ok so yeah I want a cherry bomb on mine as well but I don't want to cut the pipe that goes to my muffler if its the only one I have! I want to have the easy option to go back to a muffler if I need to for inspection or want to because I get tired of it being a little loud. So Thats why I wanted to know if a Loyale muffler would work so that I can use that if I need to! Thanks for the replies and if anyone knows for sure please let me know! Thanks
Well we dont have emissions or inspections up here, and I didnt really care if I cut the pipe as I was runnin without a muffler for a long time. $54 ticket later I bought a cherry bomb and welded it up :)
Yeah Maine is unreasonably strict on their inspections! I'm not real concerned about getting pulled over but its the yearly inspection that I kinda worry about!
  86HatchShelby said:
Idaho is always in need of subaru enthusiasts :banana:
Yeah going west is something that I wouldn't mind doing but it takes money and then I'd have to get a job as soon as I got out there and then I also love Maine! But ya never know!
I dont see why it wouldnt work if the exhaust pipe on the Brat is the correct size to fit the inlet side of the muffler - which it may, or may not be.
Only way to know for sure without cutting/fitting would be to measure - with a caliper - the outside diameter of the pipe and the inside diameter of the muffler inlet.
no inspections here either - Cherrybombs rule!!! :lol:
Yeah I'm pretty sure that the pipe will be close enough but I was just worried about the actual bend of the pipe where it comes around the rear suspenision area.
  Greenley said:
Find another stock "catback" assembly, and weld the cherry bomb to your existing pipe. That way you can swap them out with two bolts...
Yeah that's a good idea but again I'm just trying to see if I can use what I got without having to buy anything. If I had to buy another muffler, I probably wouldn't hack up the one I have just to put a cherry bomb on it.
