Headlight dilema.
if that doesn't fix it, and it should, replace the two headlight relays. They're under the dash above the pedals. They look like this. $13.00 at autozone.
But replace them with this, $8.00 and 30 amp to boot. Pilot PLRY1.
Great idea to do while Im bummin around :)
Thank You
-Jaren
hijack but related...i did the Hella conversions for all 4 lights on my brat. 2 times now, sometimes i cannot go back to just low beam, like the switch isnt working on the low. hibeam switch off, and the "beam" indicator still lit and all 4 lights are on. I had to disconnect the high lamps on my last drive. Do i need a relay, is my switch getting fried, or do i have a lamp grounded out somewhere? sometimes it works fine, but then gets stuck on high...
I'm not sure if this is your problem or not but I have seen quite a few of the actual switches go bad on these style cars...EA81. But it could ba any of the things you listed.
