EVOthis Posted December 4, 2008 Share Posted December 4, 2008 Hey guys....well i finally need to replace the tachometer head on my 96 legacy....i believe i read a thread a while ago about how this was done but i forget...my question is is this job pretty straight forward? do i need any special tools or anything?....i will hopefully be picking up a used tach. head from the JY and just wondering what all the tools i need to do it are.....the tach still reads but you can. def. tell it has the wrong RPM's....thanks for your time and knowledge.....also what other years will work....95?97? Just to specify this is just the head not the whole instrument cluster... Link to comment Share on other sites More sharing options...
frag Posted December 5, 2008 Share Posted December 5, 2008 A simple search in this forum (like "tach replacement") will get you all the info you need. Link to comment Share on other sites More sharing options...
EVOthis Posted December 5, 2008 Author Share Posted December 5, 2008 thanks frag..i managed to find the thread i needed.should have done that first...duh...lol...i do still have two unanswered questions....does it matter if i get the tach out of a manual or auto car? what year legacies will work? thanks again... Link to comment Share on other sites More sharing options...
frag Posted December 5, 2008 Share Posted December 5, 2008 EVOthis said: thanks frag..i managed to find the thread i needed.should have done that first...duh...lol...i do still have two unanswered questions....does it matter if i get the tach out of a manual or auto car? what year legacies will work? thanks again... Sorry, can't answer those questions, but someone else sure will be. Good luck! Link to comment Share on other sites More sharing options...
EVOthis Posted December 5, 2008 Author Share Posted December 5, 2008 anyone?...lol Link to comment Share on other sites More sharing options...
Rooster2 Posted December 5, 2008 Share Posted December 5, 2008 Prolly any Leggie from years 95-99. They all have the same dash, instrument panel, and guages. I wouldn't think there is any difference if the tach came from either a 2.2 or 2.5 motored car, as rpm read out is simply that on either motor. Prolly easier to pull the instrument cluster out as a complete unit from a car at a wrecking yard, then swap out the tac at your kitchen table at home. Spread out some old newspapers on the table before working, so the table stays clean. It makes my wife a lot happier when I use the newspapers for this type of work. Link to comment Share on other sites More sharing options...
RallyKeith Posted December 5, 2008 Share Posted December 5, 2008 The tach is just a module that screws into the instrument cluster. Really easy to do. Like mentioned any 95-99 legacy will do for the donor. Keith Link to comment Share on other sites More sharing options...
EVOthis Posted December 6, 2008 Author Share Posted December 6, 2008 thanks fellas....so a tach from a EJ22 or EJ25 will work 95-99....not that it should matter but does it matter if the donor car is auto or standard? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 6, 2008 Share Posted December 6, 2008 95 -99 all the instrument clusters are the same. if you find one with mileage close to yours, just swap the whole thing and don't mess with the tach it self. save the old for a spare. Link to comment Share on other sites More sharing options...
Rooster2 Posted December 6, 2008 Share Posted December 6, 2008 EVOthis said: thanks fellas....so a tach from a EJ22 or EJ25 will work 95-99....not that it should matter but does it matter if the donor car is auto or standard? No, does not matter if donor car is auto or standard. Link to comment Share on other sites More sharing options...
Rooster2 Posted December 6, 2008 Share Posted December 6, 2008 johnceggleston said: 95 -99 all the instrument clusters are the same. if you find one with mileage close to yours, just swap the whole thing and don't mess with the tach it self. save the old for a spare. Agree, much easier to simply swap in an entire instrument cluster. If you go this route, be sure to turn on the head lights to see if any bulbs are burned out in the donor instrument cluster before completely reinstalling. If so, you will want to replace the bad bulbs before finishing the project. Use bulbs from your old instrument cluster if needed. Link to comment Share on other sites More sharing options...
EVOthis Posted December 6, 2008 Author Share Posted December 6, 2008 thanks fellas....ive already considered just swapping the cluster but i dont think im going to go that route...im just going to do the tach..the directions i got earlier in the thread are phenominal....thanks again for all your help...hopefully it will be a successful swap...lol.. Link to comment Share on other sites More sharing options...
EVOthis Posted December 8, 2008 Author Share Posted December 8, 2008 thanks for all the help fellas...pulled the cluster from a 95 Lego.. and swapped the tach head out...easier than i thought....now im back to cruisin at 2500 RPM in 5th at 60mph.....again thanks! Link to comment Share on other sites More sharing options...
