This is a '90 Legacy w/a '93 EJ22T swapped in - 130K miles. Has had a high idle (1800+) til fully warm since the swap - I've check vacuum lines. Cleaned the IAC and got a little better.
I swapped the front Coolant sensor out a week ago, which made no difference.
This a.m. on a 0 degrees day (-20 wind chill) started it up and it idled high but started to surge 500+ RPM - to 2500 RPM for just a second then would return to the 1800 RPM...also, the cooling fans would cycle on/off @ the same time.
After 5 mins it the surging ceased and after 10 mins the idle returned to normal - 700 ish RPM once it was warm.
The heater was on HEAT only- neither the Heat/Def nor the Def were on.
Any feedback is appreciated.
UPDATE:
I briefly (maybe 2 secs) got a CEL this am.....likely was there yesterday, too, but today I was looking for it.
However, the RPMs did not surge like yesterday.
I'll pull the codes tonite.
There was also a clicking noise coming from the front dash - w/the defroster on and off.
What relays sit under there?
At the risk of being focused on the wrong thing, I think this is due to the super cold weather.
We're to stay well before freezing, w/overnite temps below 0, for the next week!
replace the IAC o-ring.
I noticed this O-ring was loose when I cleaned the IAC, but not having an extra lying/laying around I put it back where I 'think' it went. Does it go around the 1st step or the 2nd step above the base? In the pic below the 2 steps are visible (thanks JC/Legacy777):
Edited by wtdash
credit JC
Codes are:
45: Pressure sensor and pressure exchange solenoid valve (I have an FCD installed)
and
49: Air flow sensor - Left over from when I temporarily had a different MAF installed.
Both should have been cleared, since I removed the Neg. batt. cable for over an hour after putting the stock MAF back in, and finished the FCD installed.
Car runs fine once warmed up!
  • 5 months later...
Old post, but wanted to update since it's fixed (can't edit the original post).
Swapped in a used IAC and my high idle when cold is gone, and seems to have fixed a surging idle once warm it also had .
For the record, the wiring harness was from a '91 turbo - my engine and IAC were from a '93 turbo. The replacement IAC was from a '91...shouldn't matter, though.
I'll have to wait 'til next winter to see if fixed the <0 degrees F issue, too.
Edited by wtdash
