wtdash Posted December 14, 2008 Share Posted December 14, 2008 This is a '90 Legacy w/a '93 EJ22T swapped in - 130K miles. Has had a high idle (1800+) til fully warm since the swap - I've check vacuum lines. Cleaned the IAC and got a little better. I swapped the front Coolant sensor out a week ago, which made no difference. This a.m. on a 0 degrees day (-20 wind chill) started it up and it idled high but started to surge 500+ RPM - to 2500 RPM for just a second then would return to the 1800 RPM...also, the cooling fans would cycle on/off @ the same time. After 5 mins it the surging ceased and after 10 mins the idle returned to normal - 700 ish RPM once it was warm. The heater was on HEAT only- neither the Heat/Def nor the Def were on. Any feedback is appreciated. Link to comment Share on other sites More sharing options...
crockettbrat Posted December 14, 2008 Share Posted December 14, 2008 Are you getting any codes? Have you checked the tps? My ej brat had a surging problem that threw a code for the idle switch which is part of the tps. You might want to check the voltage at the ecu for the tps and the idle switch. Hope this helps. Daniel Link to comment Share on other sites More sharing options...
wtdash Posted December 15, 2008 Author Share Posted December 15, 2008 UPDATE: I briefly (maybe 2 secs) got a CEL this am.....likely was there yesterday, too, but today I was looking for it. However, the RPMs did not surge like yesterday. I'll pull the codes tonite. There was also a clicking noise coming from the front dash - w/the defroster on and off. What relays sit under there? At the risk of being focused on the wrong thing, I think this is due to the super cold weather. We're to stay well before freezing, w/overnite temps below 0, for the next week! Link to comment Share on other sites More sharing options...
Valkyrie Posted December 15, 2008 Share Posted December 15, 2008 replace the IAC o-ring. Link to comment Share on other sites More sharing options...
wtdash Posted December 15, 2008 Author Share Posted December 15, 2008 (edited) replace the IAC o-ring. I noticed this O-ring was loose when I cleaned the IAC, but not having an extra lying/laying around I put it back where I 'think' it went. Does it go around the 1st step or the 2nd step above the base? In the pic below the 2 steps are visible (thanks JC/Legacy777): Edited December 15, 2008 by wtdash credit JC Link to comment Share on other sites More sharing options...
wtdash Posted December 16, 2008 Author Share Posted December 16, 2008 Codes are: 45: Pressure sensor and pressure exchange solenoid valve (I have an FCD installed) and 49: Air flow sensor - Left over from when I temporarily had a different MAF installed. Both should have been cleared, since I removed the Neg. batt. cable for over an hour after putting the stock MAF back in, and finished the FCD installed. Car runs fine once warmed up! Link to comment Share on other sites More sharing options...
wtdash Posted May 19, 2009 Author Share Posted May 19, 2009 (edited) Old post, but wanted to update since it's fixed (can't edit the original post). Swapped in a used IAC and my high idle when cold is gone, and seems to have fixed a surging idle once warm it also had . For the record, the wiring harness was from a '91 turbo - my engine and IAC were from a '93 turbo. The replacement IAC was from a '91...shouldn't matter, though. I'll have to wait 'til next winter to see if fixed the <0 degrees F issue, too. Edited May 19, 2009 by wtdash Link to comment Share on other sites More sharing options...
