The Dude Abides Posted December 16, 2008 Share Posted December 16, 2008 How is it affecting your soob. I let it warm up for 15 minutes only to find not only a puddle of antifreeze but a puddle of oil as well. I watched the temp gauge flutter up and down all the way home. It didnt want to idle at first so i had to hold the gas until it cooperated. I have a sick suby:( Link to comment Share on other sites More sharing options...
subiemech85 Posted December 16, 2008 Share Posted December 16, 2008 well, let's see..... fuel pump control circuit decided to quit working, jumper wire used instead started quite well at a balmy 0*f no choke, just pump it 8 times, turns over just fine thanks to the 5w30 after it ran for a little bit, released the clutch too quickly which killed the engine -- after a quick battery recharge, lit up right away then let it sit until about 6pm with block heater working -- fired up like it was 70 and sunny I (love) my block heater just a fyi, it's warmer in Sveden, even above the arctic circle scroll down to bottom of page in link for weather!! http://www.sr.se/cgi-bin/International/nyhetssidor/index.asp?nyheter=1&ProgramID=2054 Link to comment Share on other sites More sharing options...
The Beast I Drive Posted December 16, 2008 Share Posted December 16, 2008 I am so glad I got my choke working, last year I had to wedge my shotgun on the gas pedal to keep it running while I ate breakfast. 3 degrees tonight, -3 or so wind chill. Whats funny is I can fire up the Beast on the coldest of days, its weberized, but my "superior" fuel injected RX will not start no matter what I do. On a normal day it will start fine, but it does not like the cold at all. And I hate driving it in the cold, as the heater core is clogged, so I get no hot air -Bill Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted December 16, 2008 Share Posted December 16, 2008 my heater core blew on the coldest day of the year... it doesnt want to idle... i think it's a soob thing Link to comment Share on other sites More sharing options...
The Beast I Drive Posted December 16, 2008 Share Posted December 16, 2008 my heater core blew on the coldest day of the year... it doesnt want to idle... i think it's a soob thing Nah, my Bronco II did the same thing... -Bill Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 16, 2008 Author Share Posted December 16, 2008 yea guys i think my car is out for the season. Well see what tomorrow brings but me and the wife are looking at other avenues. And no it doesnt involve getting rid of the car. Link to comment Share on other sites More sharing options...
zyewdall Posted December 16, 2008 Share Posted December 16, 2008 I've always had good luck with subaru's in the cold. The Justy started yeterday morning at -3F just fine. My '89GL wagon never had trouble with the cold, and even the older carbureated subaru's started in the cold fine (yes, one of them often refused to idle when warm, but it never failed to start in the cold.....). I run 5W50 synthetic in them -- gotta put synthetic in the Justy's transmission... it felt like molasses in the morning... I've never had a block heater on any of them. I could not for the life of me get my old tractor started yesterday though. Jumping another battery to the starter motor to crank it faster, starter fluid, everything.... not even a pop. Oh well.... Guess I need a block heater on it Z Link to comment Share on other sites More sharing options...
presslab Posted December 16, 2008 Share Posted December 16, 2008 I love my soob in the cold, hot air out of the vents in 2 mins! It's cold for here (N. Cal) but only about mid 20s F at night. A while ago I noticed that the heater duct on the pass side (by the center console, under the dash) was leaking a lot of cold air. I tightened up the metal strap with some wire and it's been great since. Link to comment Share on other sites More sharing options...
bheinen74 Posted December 16, 2008 Share Posted December 16, 2008 (edited) Ben, maybe your water pump......the seal has gone....i have been taking the White SS this last week. I drove the Brat Sunday before it dropped 50 degrees in 4 hours. Its snowing now, so when i get home from work, will be taking the Brat out for some fun in the snow. Edited December 16, 2008 by bheinen74 Link to comment Share on other sites More sharing options...
hatchsub Posted December 16, 2008 Share Posted December 16, 2008 My subaru has a nasty habit of starting/dying, starting/dying, starting/dying then on the fourth or fifth time actually stay running. I need to adjust my choke on the weber. Other than that it runs fine. I double clutch 2nd and third until its warm otherwise they like to grind. Syncros are too cold to keep up. Link to comment Share on other sites More sharing options...
zyewdall Posted December 16, 2008 Share Posted December 16, 2008 Ben, maybe your water pump......the seal has gone.... I had something similar happen on my old '85 GL wagon once -- on a very cold day (-5F or so) it overheated badly, and started spurting coolant and dripping oil it got so hot. I don't know if it was a bad thermostat that stuck closed, or if the coolant started icing up and clogged the radiator or what... but that engine was HOT. The next day it was fine... but about 6 months later it developed head gasket trouble. Z Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 16, 2008 Author Share Posted December 16, 2008 Yea i dont know what the deal is. Ill go out there alittle before work to see whats going on. I added a qt of oil after i noticed the puddle last night. I saw that temp gauge go slowly up then all of a sudden it went down to the normal mark. Frozen rad prehaps. I probally dont have a good mix in there. Link to comment Share on other sites More sharing options...
Rag_v2 Posted December 16, 2008 Share Posted December 16, 2008 Mine has been starting up right away, but makes a ton of (lifter?) noise. I just did an oil change too. I put in 10w-30, I meant to put in 5w-30. I did mind until the cold air hit. Runs great, just noisy for the first 15 minutes. Link to comment Share on other sites More sharing options...
Wirebrush Posted December 16, 2008 Share Posted December 16, 2008 -20 This morning. It's the first time my Brat has refused to start due to the cold. I'm kinda surprised it's done so well considering it came from Florida. I guess I'll have to put a block heater in it, but that won't help much when I'm away from home and don't have a place to plug it in. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 16, 2008 Share Posted December 16, 2008 I saw that temp gauge go slowly up then all of a sudden it went down to the normal mark. Frozen rad prehaps. I probally dont have a good mix in there. temp up then down, sounds like the Thermostat sticky, then it releases, I prefer the best thermostat when it comes to a Subaru Link to comment Share on other sites More sharing options...
subiemech85 Posted December 17, 2008 Share Posted December 17, 2008 suck-o-matic 4x4 control system quit working, doesn't engage Link to comment Share on other sites More sharing options...
bheinen74 Posted December 17, 2008 Share Posted December 17, 2008 just went out now to the BRAT, which is in a very cold non heated garage. pumped pedal as turned key, gave 3 pumps, started right off. smoothly backed it out, engaging 4wd lever. it is now warming up at idle, i came back in. I am just going to go like 4 blocks to the bar for a drink. might take the cam to get some pics, still snowing. I can hear the boxer running still. Link to comment Share on other sites More sharing options...
rpiereck Posted December 17, 2008 Share Posted December 17, 2008 My Loyale is a seasoned Alaskan veteran, it starts up at -30 with not a hiccup It just takes forever to warm up!!! I ordered some Wagan heated seat cushions to remedy that! Link to comment Share on other sites More sharing options...
DaveT Posted December 17, 2008 Share Posted December 17, 2008 Synthetic engine oil definatly helps cranking in the cold. I also use the biggest battery that will fit in the battery space. My 76 & 78 4X4s (manual) shifted same as warm weather after I started using synthetic gear lube. The 3ATs I drive now all function better cold with synthetic ATF. Link to comment Share on other sites More sharing options...
Spiffy Posted December 17, 2008 Share Posted December 17, 2008 How is it affecting your soob. not good! I have to keep the pedal to the floor on the ea81 until it warms up... with the pedal to the floor it runs around 1500 rpm, rough... after that all is great... I think I'm using a ton of fuel during that warm up time because my mileage is the suck right now... need to figure out what's causing it... I'd much rather be inside where it's warm while I wait for it to warm up... it was about 5°... but I think anything too far below freezing makes it not idle when cold... could my cold idle circuit be frozen or something? --Spiffy Link to comment Share on other sites More sharing options...
bheinen74 Posted December 17, 2008 Share Posted December 17, 2008 i just went down a level B service road a while ago, heated driver seat was getting nice and toasty.....mmmmmm, heater worked excellent too. some drifts were max about a foot. otherwise i would say like 4 inches snow fell today. Link to comment Share on other sites More sharing options...
dhise Posted December 17, 2008 Share Posted December 17, 2008 snowing and cold, cold, cold here too. The wagon starts and runs just fine, but the suspension creaks and groans a bit in the sub-zero stuff. Sometimes the lifters make a racket too in the morning. 4x4 still works, had a chance to use it tonight with some fresh snow on the ground. Link to comment Share on other sites More sharing options...
bratman18 Posted December 17, 2008 Share Posted December 17, 2008 Yeah it's been either real cold or warm here. Yesterday it was 56! Then today was below freezing all day. We are getting around 6" of snow tomorrow though and then more on Friday and then more on Sunday! That means I get to plow with my wheeler!!! Link to comment Share on other sites More sharing options...
Numbchux Posted December 17, 2008 Share Posted December 17, 2008 my 275k mile EJ22 in my loyale really doesn't like it. even with the red top, it just won't fire up below unless it's had the block heater on. And even then, I let it idle for about 25 minutes this morning (heat off, rad fan off)....and it still barely moved the temp gauge. the XT6 fires up pretty easily, this morning (14 below) it cranked pretty slow at first, but still no trouble. and it warms up quick too! Link to comment Share on other sites More sharing options...
paulpicard Posted December 17, 2008 Share Posted December 17, 2008 Had cold start/run issues with my EA-82 last winter (92 Loyale wagon). Serviced the idle air control valve, put a seal kit in the oil pump, installed a new t-stat, and cleaned up the temp sensor contacts this fall, all thanks to the good advice and how-to's here. Starts and idles just fine now (overnight ambient temps -25C last 2 days) The block heater makes it even better (the car was missing the connector cord last year) I get heat within 5 minutes after only 2 hours plugged in. 5-30 in the engine. Gearbox (5 speed 4 wheel drive) is like molasses, what are you guys running in yours? Link to comment Share on other sites More sharing options...
