WickedV6 Posted December 16, 2008 Share Posted December 16, 2008 I have signal and brake lights however no tail lights or front side marker lights. I checked the fuse labled "tail" in the kick panel on the drivers side. It looks good. Am I missing something? Am I looking at the right fuse? This is a 1995 Legacy. T.I.A Prasad Link to comment Share on other sites More sharing options...
bratman18 Posted December 16, 2008 Share Posted December 16, 2008 Check all fuses! Not just one. I had this happen to me when I installed an aftermarket radio. It shorted and blew the fuse and it ran the tailights as well. Link to comment Share on other sites More sharing options...
nipper Posted December 17, 2008 Share Posted December 17, 2008 This happened to me, the virgin switch was in the middle. Move the parking light switch back and forth first and see if that fixes it. nipper Link to comment Share on other sites More sharing options...
bratman18 Posted December 17, 2008 Share Posted December 17, 2008 nipper said: This happened to me, the virgin switch was in the middle. Move the parking light switch back and forth first and see if that fixes it. nipper ahhh, yes I forgot about that! +1 Link to comment Share on other sites More sharing options...
WickedV6 Posted December 17, 2008 Author Share Posted December 17, 2008 nipper said: This happened to me, the virgin switch was in the middle. Move the parking light switch back and forth first and see if that fixes it. nipper I did try that as well, no luck. I will check all the other fuses. Thanks guys Prasad Link to comment Share on other sites More sharing options...
nipper Posted December 17, 2008 Share Posted December 17, 2008 DO the parking lights come on with the virgin switch? If it doesnt check the fuses. If it does its the relay. nipper Link to comment Share on other sites More sharing options...
WickedV6 Posted December 19, 2008 Author Share Posted December 19, 2008 nipper said: DO the parking lights come on with the virgin switch? If it doesnt check the fuses. If it does its the relay. nipper No, the parking lights do not come on with the virgin switch. I will go through every single fuse. Thanks Prasad Link to comment Share on other sites More sharing options...
nipper Posted December 19, 2008 Share Posted December 19, 2008 Yup its a fuse. The switch bipasses the relay. nipper Link to comment Share on other sites More sharing options...
WickedV6 Posted December 22, 2008 Author Share Posted December 22, 2008 As always you guys were right on the money. I double checked the fuses. This time I checked with a multimeter. The fuse for the parking lights looked perfectly fine but when I checked for continuity, it showed it was open. It had a hair line break in it. Repalced the fuse and we are all good. Thanks again guys Prasad Link to comment Share on other sites More sharing options...
lighthousekeeper Posted December 29, 2008 Share Posted December 29, 2008 I am having the same problem with my 1996 outback except i have checked every fuse with a multimeter for continuity and they are all fine. I even went so far as to check every fuse besides the air bag for continuity and they are all fine! I cannot get my dash or parking/tail lights to work only the brakes. The strange thing is that the lights will all flash on like they are supposed to when i click my remote starter/alarm. Im afraid i might need a new switch. Also what is the virgin switch you spoke of? Thanks Link to comment Share on other sites More sharing options...
nipper Posted December 29, 2008 Share Posted December 29, 2008 The switch on top of the steering column for the parking lights. nipper Link to comment Share on other sites More sharing options...
